Join TechIMO for Free!
Thread Tools
Currently Active Users: 2229
Discussions: 186,591, Posts: 2,226,873, Members: 230,214
Old August 17th, 2004, 05:48 AM   Digg it!   #1 (permalink)
LeftCoast's Avatar
WHICH SWITCH?? Help choose the correct toggle switch.
Hi all,
Need a switch question answered, but wiring's not my forte. Any help selecting the correct switch and wiring tips would be very appreciated.
I need one push button toggle switch (not a momentary switch; just on-off) that will alternate between two devices (say an 80mm case fan and a 120mm case fan). In other words, when the switch is depressed (it stays pressed), the 80mm fan is on, while the 120 is off. Then, when pressed again (or released), the 80 is turned off while the 120 is turned on. I'm thinking to accomplish this I will need a DPDT (double-pole,double-throw) switch, but obviously being a wiring newb am not certain. Basically, I want one switch to perform the functions of two SPST switches that would always be in opposite positions, if that makes better sense.
Again, any wiring tips/advice you could give would be most appreciated.
Millions long for immortality who don't know what to do with themselves on a rainy Sunday afternoon.
Susan Ertz
LeftCoast is offline   Reply With Quote
FREE instant scan
Old August 17th, 2004, 03:13 PM     #2 (permalink)
TheBlueFace's Avatar
I want an off/on button for light in my case, I bought one switch at xoxide, but need wiring help.
There is always a better way.
TheBlueFace is offline   Reply With Quote
Old August 17th, 2004, 03:18 PM     #3 (permalink)
I am a banana!
originel's Avatar
Send a message via AIM to originel
well you can always get a 3 way switch. they usually have a center "dead" area where both devices would be off. Other than that i'd recommend just hunting around radio shack. As for the wiring that could be fun. Do you know how to solder?
originel is offline   Reply With Quote
Old August 17th, 2004, 04:42 PM     #4 (permalink)
LeftCoast's Avatar
I think I can solder enough for this project! I'd really prefer a push button toggle switch, if possible.
Old August 18th, 2004, 12:25 AM     #5 (permalink)
LeftCoast's Avatar
Bump!
Old August 18th, 2004, 02:20 PM     #6 (permalink)
I am a banana!
originel's Avatar
I guess just look around on sites like www.mouser.com and www.digikey.com for a push button switch. Have you been to radio shack yet? they have a ton of switches (at least where i live they do).
What i'm thinking is this switch should have 4 leads on the bottom of it. You'll find the hot wire (probably the 12v) that is powering the fan and cut it, soldering each lead to one end of the cut wire.
Old August 18th, 2004, 02:25 PM     #7 (permalink)
LeftCoast's Avatar
The more I think about it, I'm thinking I need a SPDT push button switch...
Thanks for sticking with me on this one,originel. I've see the digikey site (a real muthuh to find what you need), but I'll check out mouser as well.
Old August 18th, 2004, 02:42 PM     #8 (permalink)
I am a banana!
originel's Avatar
yeah, digikey can be a real pain, but they're pretty reliable and have a lot of stuff. you just really have to know what you are looking for.
btw, here's a search for a bunch of switches that look like they will work.
Old August 18th, 2004, 02:45 PM     #9 (permalink)
(AKA) Nakamura
sweeper2's Avatar
sounds to me you would need a relay with one contact NO and another NC , but when pwr is supplied to the relay coil, it would close the NO contact and open the NC contact. It would have to be wired in conjuction with a pwr switch, kinda like you would use to turn on/off your pc.
http://www.installdr.com/TechDocs/999403.pdf
http://www.grainger.com/Grainger/wwg...anchSearch.jsp
you could try ^^^^ there also... look up if you have one in your area...
hope this helps a little
Old August 20th, 2004, 06:52 PM     #10 (permalink)
Try looking for a SPST push button switch that has has a switching function of "on-on". SPST of this type may be hard to find so a DPDT will do fine. There are 3 terminals on this switch(SPST)- usually solder type. The center being the common or center pole connection. Solder your supply gnd (from power supply or connector) lead here then solder the each negative lead of the the two fans to the outer terminals of the switch. Finally connect the two red leads from the fans to the B+ side of power supply or connector.
The only reason why your switching the gnd instead of the B+ at the switch is that, if for any reason a metal portion of the case or screwdriver touches these leads it won't short-out the power supply.
Thanks to Originel for doing the leg work, this "type" of switch should do the trick:
http://dkc3.digikey.com/PDF/T042/1015.pdf
part number - CKN4016-ND(digi-key)
TypicalNuser is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Problem trying to connect "AT" form factory case to a atx motherboard spreeway General Tech Discussion 9 June 18th, 2004 12:39 AM
Toggle with an ATX thePh@r@oh PC Modification 9 January 13th, 2003 12:41 AM
Desktop PC mod thePh@r@oh PC Modification 20 January 12th, 2003 12:41 AM
Is It Just Me? (492)
heatsink issue (8)
Why Does the MOON Grow Bigger as It.. (11)
SSD's, RAID, and External Backup (5)
New Mobo (16)
1 internet. 1 house. 3 computer. ho.. (11)
Connected to LAN but unable to use .. (5)
SSD's, RAID, and External Backu.. (5)
1 internet. 1 house. 3 computer.. (11)
heatsink issue (8)
Hard Core Overclock (7)
FS: New Benny Hill Megaset DVD .. (6)
Computer won't start (2)
New Mobo (16)
Request for recovary system ins.. (0)
Folderchat: The Holiday thread (111)
am2 on 939 (4)
