Fan behind cpu?  | | |
September 6th, 2004, 12:08 PM
Just a thought..
Why not have a fan behind the cpu on the right side panel? so it blows cool air behind it and away... Any comments on this idea?
__________________ RackByte.com - Web Hosting / Reseller Hosting / VPS / Dedicated Servers / Domain Registration
September 6th, 2004, 12:13 PM
| | Now in the nicer ghetto
to my knowlege, the backside of the motherboard does not get nearly hot enough where that would make a noticable difference, but if you find otherwise, feel free to prove me wrong
I don't like signatures.
September 6th, 2004, 12:14 PM
well i have thought of that aswell but i tried it and found that the mount for my mobo is to close to the side pannel. but that is in my case. wont it just cool your mobo more then your cpu |
ya i figured that... maybe ill try it one day :P dun feel like cutting my lian li into peices  |
September 6th, 2004, 12:17 PM
maybe you can use a thing fan some thing like the fan that is on the amd 3000+ socket a |
September 6th, 2004, 12:20 PM
| Quote: |
Originally Posted by proffit maybe you can use a thing fan some thing like the fan that is on the amd 3000+ socket a | i was thinking of just cutting a 80mm for a slim fan in the side panel for cooler+more cfm |
September 6th, 2004, 12:27 PM
| | still smoke free
You could always try to direct air behind the motherboard tray with a little ducting from a remote fan. |
September 7th, 2004, 02:48 AM
| | I'm silently judging you
If you got a case such as what I have, with 120mm fans and then reversed the flow, that might help pure CPU cooling. The one I have is a Super LANBoy, a good chunk of the fan would blow right onto the heatsink and fan of my proc if I turned it around.
Just a thought. |
September 7th, 2004, 08:37 AM
| Quote: |
Originally Posted by ArcticFox If you got a case such as what I have, with 120mm fans and then reversed the flow, that might help pure CPU cooling. The one I have is a Super LANBoy, a good chunk of the fan would blow right onto the heatsink and fan of my proc if I turned it around.
Just a thought. | youve got the idea wrong :P the right panel next to the motherboard. |
September 8th, 2004, 04:41 PM
| Quote: |
Originally Posted by kantlivelong youve got the idea wrong :P the right panel next to the motherboard. | Naah, I'm just pointing out you can do a similar thing in some cases (pun not intended). |
