looking for a fan controller...
Currently Active Users: 1413
Discussions: 204,526, Posts: 2,419,671, Members: 249,950
Old September 27th, 2005, 03:20 PM   Digg it!   #1 (permalink)
Mobile Member
ShuckyD's Avatar
Im in the market for a fan controller similar to this one
http://www.zipzoomfly.com/jsp/Produc...uctCode=371024
But what i want is the ability to do at least 4 fans and be able to control them to turn off and then on and some with speed control like the one shown, but the connectors for the fans have to support both molex(4pin) and 3 pin conectors since my 120mm fan has molex and some others have 3pin.. the bad thing about this one is that its on backorder.
If you see any on this site or another site that meet what i describe please post a link i'll probably buy one in a day or so if i can find a reasonable deal
http://www.newegg.com/Product/Produc...82E16813999251
Mobile: Thinkpad T61 14.1" wide | WinXP Pro | C2D T8300 CPU | 3GB DDR2 | 160GB HDD | AGN & WWAN
Desktop: WinXP x64 | 3Ghz Phenom II X4 | 4GB DDR3 | 256mb 8600GT | 6x SATA HDD's for Photography
ShuckyD is offline   Reply With Quote
Old September 27th, 2005, 04:18 PM     #2 (permalink)
Training for Bankai
JPMiller's Avatar
http://www.svcompucycle.com/svcompucycle/fancont35.html
http://www.svcompucycle.com/svcompuc...ontroller.html
In my opinion, SVC is the best place to buy the small stuff...
you can always get adapters as well...
http://www.svcompucycle.com/svcompucycle/conad.html
Old November 7th, 2005, 11:14 PM     #3 (permalink)
one large transistor (5 amp ish), one 5 k potentiometer, one 1/4 watt 330 ohm resistor, a heat sink, female and male molex plugs, some solder shrink wrap and patience. Thats the kind i use. Home made and they work great. If seriously interested ill explain how in detail...
btw this isnt pulled outta my rear i took a year or two of electronics
Amd athlon 64 3200+ asus a8v-e se 1gig geil ddr bfg7800gt 120 and 160 gig maxtor lg dvd burner Hec 550w psu and way too many fans
pick_arse is offline   Reply With Quote
Old November 7th, 2005, 11:20 PM     #4 (permalink)
mjolnir1134's Avatar
http://www.newegg.com/Product/Produc...82E16811998129
eh? eh?
Kinda planning on getting this later on in my crazy adventure in computer upgrading.. and wizardry.
EEE 1000H—1.6Ghz—1GB RAM—XP
mjolnir1134 is offline   Reply With Quote
Old November 8th, 2005, 07:55 AM     #5 (permalink)
Mobile Member
ShuckyD's Avatar
heh i got one of them with my cooler master HSF, and i got one of them in the box with a 80mm fan i got, they are pretty neat :-D i just dont like having to reach around to change the fan speed (hmm....can you say lazy)
Old November 8th, 2005, 12:42 PM     #6 (permalink)
Send a message via AIM to Failed
I have that zalman you showed, havent had a single problem ,was easy to install/use. Only thing I didnt like is the lights are bright when i went to bed and the comp was in my room. So i would turn the fans down just to make the lights dimmer. Now comp is not in my room and I love them.
Athlon 64 3200+ (2.25ghz)
MSI K8N Neo2 Plat
BFG Geforce 6800 (12x6 372/739)
E-Power Puma II PSU
1GB Crucial Ballistix PC4000
Failed is offline   Reply With Quote
Old November 8th, 2005, 12:53 PM     #7 (permalink)
Originally Posted by Failed
I have that zalman you showed, havent had a single problem ,was easy to install/use. Only thing I didnt like is the lights are bright when i went to bed and the comp was in my room. .
i was actualy going to buy that, but i got turned off because of the lights, it seems like everything now comes with lights on it. i had to paint my usb hub because the blue lights lit up my room so much at night.
Just Say No To LEDs And Neons
[Cerberus] is offline   Reply With Quote
Old November 8th, 2005, 12:59 PM     #8 (permalink)
Ya I use to think lights were cool, but I had a million blue lights all over my case I couldnt sleep.
Old November 8th, 2005, 01:28 PM     #9 (permalink)
zepper's Avatar
The Zalman controller can only handle 7W per fan - that is about 0.6 Amps and may not be able to shut some fans completely off as it only goes down to 6.5V equivalent. Many fans these days can run on down to 5V or less. Most all fan controllers have only 3-pin fan connectors and 2 or 3-wire extensions with 3-pin connectors on both ends, one male one female. If you need to use 4 pin fans, you'll have to order extra adapters along with the controller or just replace the fan connectors with standard 3-wire female - both of the companies I linked have contacts and shells to do that mod.
. I've seen the Sunbeam Rheobus controllers for under $10 recently that have a 0 to 12V range and supplies up to 20W per fan. I've heard that those Sunbeams don't include any extensions/adapters other than for the main power (drive power extension M/F). So you'll need to order what you need along with. Check at jab-tech.com and svc.com . Sunbeam Rheobus controllers work well with all fans as they are linear - others like CoolerMaster and probably the Zalman use PWM control circuits that can cause some fans (e.g. Panaflo and other sleeve bearing tipes) to buzz.
.bh.
zepper is offline   Reply With Quote
Old November 9th, 2005, 01:14 AM     #10 (permalink)
Sounds like u know what your talking about. Good job. I just picked one that had a name brand (zalman) and looked cool lol
Fan controller!!! skeltonjoe PC Modification 1 February 27th, 2005 11:17 AM
fan controller rickytim PC Modification 7 February 1st, 2004 01:46 AM
Fan controller and fan failure whatmeworry Technical Support 3 October 5th, 2003 12:12 PM
Fan controller CraigK PC Modification 6 June 26th, 2003 05:40 AM
What Fan controller u use? joker_927 General Tech Discussion 10 March 27th, 2003 06:35 AM
Is It Just Me? (1635)
An Inability to Be Civil (23)
newegg=bad people (32)
USB not recognised..... (16)
Need some suggestions on building a.. (35)
Recent Problem (15)
First time builder (6)
HTML (7)
[ F@H Chat] 03/07/10 New Month New.. (92)
Motherboard the culprit? (7)
Windows XP Pro Error log (9)
Suggestions? (6)
Message from webpage (2)
Microsoft removes hardware virtualiza.. (2)
How to transfer iPod files to iPod/Co.. (0)
pc won't start (2)
Need some suggestions on building a g.. (35)
Processor speeds? (20)
Outlook keeping 2 copies of sent mess.. (3)
Recording Audio from a website? (8)
SSH Tunnel Or OpenVPN? (2)
TV tuner (1)
C# Sql Server 2005 Connection Issue (0)
GOM Player with Google Chrome? (0)
First Time PC Builder (Gaming PC) (1)
[ F@H Chat] 03/07/10 New Month New T.. (92)
HTML (7)
re laptop (1)
Audio skips when I play a cd or dvd o.. (2)
Lexmark Printer Prestige pro805 (1)
Hypercam 2 plays sound too fast (1)
IE8 & WLM crash whenever I try to.. (1)
iPad, who's getting one? (60)
Writing lead-out (8)
