January 2nd, 2006, 05:54 PM
| Case fans noisy, then quiet!
I had a computer built for me several years ago through one of the online retailers. No problems for the most part. I requested extra fans put into the side panel (2).
For ~1 year, no problems. Then, starting ~1 year ago, whenever I boot my computer, these 2 side panel fans make a horrendous racket. No cables or anything are hitting the fans, they're just noisy as heck. About 1-2 minutes after they start up, about the same time Windows pops up, they quiet down to what I'd consider normal.
I've cleaned out the dust as best I could (maybe helped?). Do they just need oiling? |
January 2nd, 2006, 06:06 PM
If you have cleaned all the dust off the blades then the next thing to try is to peel the lable off the motor to expose the armature shaft and apply a drop of oil (3-1 oil would be best). If that does not do it than replacement is in order.
Sounds like cheap fans to have problems so soon.
__________________ Gigabyte GA-M57SLI-S4, Athlon 64 X2 5400+
2 Gig DDR2 800, GeForce 6600 128meg Nvida Driver 169.21
Win XP Home SP3 |
January 2nd, 2006, 06:27 PM
Your fans are going south on you.
Look here for new ones: www.nexfan.com
I always order a few 80mm case fans when I get stuff from them. Even their cheapo $1.50 fans last a long time and are quiet. I just put one in an Enermax power supply yesterday because the original fan was making a horrendous racket.
Benjamin Franklin
January 8th, 2006, 09:18 PM
| | still smoke free
most case fans have a sleeve bearing, which is a garbage bearing for long term use. they have a tendancy to lose their lubrication and if the motor shaft goes crooked for some reason, you're going to get a lot of wear on one part of the bearing causing a squeal or noise. I always try to buy ball bearing fans whenever possible for that reason. |
January 10th, 2006, 09:07 PM
Finally detached them from the case... 2 Raidmax ball bearing fans. Still quite a bit of dust on the blades. But I'll peel the label off to oil and try again. Weird that they quiet down after ~2 minutes of "warm-up." |
January 10th, 2006, 09:17 PM
| | still smoke free
Could be that the bearings are getting "stuck" on a groove or notch ( possibly melted by an overheated bearing when it came to rest ). I'm sure the bearings are starved for lubrication.
Good luck, hopefully the 3n1 will solve your woes. |
January 11th, 2006, 07:03 PM
| | Human voltmeter
| Quote: |
Originally Posted by waylo Weird that they quiet down after ~2 minutes of "warm-up." | This is typical behavior for an oil-starved sleeve bearing. The noise you hear is probably due to the shaft wobbling in the bearing. THAT'S BAD, because it puts stress on the shaft and the bearing, and wears them both out. As the bearing warms up, some oil flows back into the shaft-bearing interface, reestablishing proper operation.
BTW, DON'T use the regular 3-in-1 oil in the red can. It's good for general lubrication, but not that great for sleeve bearings. 3-in-1 makes another oil in a BLUE can that's specifically formulated for electric motors: http://www.wd40.com/Brands/3in1_product_info.html
Non-detergent SAE 30W oil is also commonly recommended for sleeve bearings.
I've tried regular automotive 10W-30 a few times cause that's what I had lying around at the time. It worked for a few weeks but eventually the bearing runs out of oil again. My guess is that the viscosity wasn't high enough to "stick" to the bearing. Plus the oil was formulated for internal combustion engines, a very different environment from electric motor sleeve bearings.
January 13th, 2006, 12:24 PM
DanU:
Thanks again. Followed your instructions to the letter and the first run at least is smooth/quiet. This is the 2nd consecutive issue you've settled with my computer on this forum! |
January 13th, 2006, 06:12 PM
| | Human voltmeter
Hey that's great! What oil did you use? |
January 13th, 2006, 09:22 PM
The 3n1 motor oil (blue label). Walked into Ace Hardware and found it almost immediately. Funny, since this local store looks like such a cluttered mess. |
