I am looking into buying a Zalman Reserator 1. I want to buy a replacement pump (Danger Den DD-CPX1 12V Pump), install it inside the reservoir, and hook the power into the Reserator power cable. The stock pump operates at 5W and the Danger Den operates at 6W. Does anyone have any idea what I can do accomplish this?
This obviously is from the manual and doesn't really help much.
