September 27th, 2007, 05:14 PM
| 1st build, parts suggestions? |
September 27th, 2007, 06:22 PM
Looks good to me. All are premium parts, and should work well together. You even know enough to get Vista 64-bit with 4gb+ of memory...
Enjoy it.
Edit - The only thing I can think of is if you wanted to a save a little bit of money and downgrade the graphics to one with less memory seeing as the memory does very little for the gaming at this point in time... But, no one knows what the future beholds, so... Yeah. Go for it.
__________________ Intel Core 2 Quad Q6600 OCed 50% (3.6GHz) | ASUS P5K Deluxe w/ WIFI | G.Skill 4096MB (4x1024MB) RAM | Foxconn GF8800 GTS 640MB | WD Raptor 150GB |
September 27th, 2007, 07:40 PM
just to make sure, you do realize that driver support for 64-bit is really bad and some of your software/hardware may not work properly or at all? |
September 27th, 2007, 07:53 PM
| | 分かりますか。
Get a SATA optical drive.
No reason to buy IDE drives anymore.
If you have the money, you could step up the RAM to DDR2 1066.
The sound card proly isnt needed.
But the list looks good. |
September 27th, 2007, 08:22 PM
| | Folding@home since 1862!
Yeah I agree with carl on the sound card. Most of the time you can't really tell the difference. I would suggest setting up the system with just onboard, and then if it doesn't sound good enough for you, then pick up the sound card.
And definitely get a sata burner. They're the same price anymore, and alot faster. Plus you don't have that ugly IDE cable blocking the air flow.
My only other thought would be swap out the PSU for this. It's got that same amount of amps and total power as the one you listed. It will look alot better with your case. Plus it's cheaper off the start, with a rebate to make it cheaper.
Other then that, that's a sweet ass system.  |
