Join TechIMO for Free!
Thread Tools
Currently Active Users: 2925
Discussions: 186,568, Posts: 2,226,571, Members: 230,204
Old February 2nd, 2008, 03:22 PM   Digg it!   #1 (permalink)
Prince Lalijama's Avatar
Send a message via MSN to Prince Lalijama
Fan help
I'm going to install 2 fans for the front of MUH CASE! Mine is blue, but that is irrelevant, anyway, they have two slots for 80mm fans in the front according to the reviews, do you guys think this will help with airflow at all? Look at the pictures of its front with the door open, I usually leave the door closed and some reviews say that fans in the front don't help with flow at all.
Not really a Mod discussion but case modders would know more about this than just the average joe.
I'm PL, I've come to suck all the intelligence out of this thread.
Prince Lalijama is offline   Reply With Quote
FREE instant scan
Old February 3rd, 2008, 08:48 PM     #2 (permalink)
SPY BUMPIN' MUH THREAD!
Even though its on top of mod discussion, I should have put it in General.
Old February 3rd, 2008, 08:58 PM     #3 (permalink)
(AKA) Nakamura
sweeper2's Avatar
I'm sure the fans would do some good, or they wouldn't have put the slots there.. they will probably suck up from the bottom inbetween the front door and the front fan area ..
if you have one blowing OUT at the rear and those two sucking air into the case, you should get some good airflow
P4 2.8ghz / MSI 865PE Neo2-PS / GeCube Radeon X1950XT 256mb agp / 2gb DDR400 / 2 X 80gb Samsung HD
Old February 3rd, 2008, 09:33 PM     #4 (permalink)
I have 2 blowing out, one on top and one on back. And my PSU fan is 120mm and I see a ticket thing hanging from the wall flappin around.
Old February 3rd, 2008, 11:39 PM     #5 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
Having the fans up front will help greatly with the airflow.
Chappaquiddick 1 - Dick Cheney 0
Atomic Rooster is offline   Reply With Quote
Old February 4th, 2008, 01:15 AM     #6 (permalink)
zepper's Avatar
Lightbulb
Front fans are generally for cooling the HDDs, the rear exhaust is generally responsible for setting up the air flow. With one in and two out, the exhausts may be starving for air unless there is adequate vents for it to draw from. Open the case and check the rpm of the rear fan, close it again and recheck after a while. If the rpm dropped, then the case is restrictive. If so then add another or a stronger intake fan or open up some venting (the closer to the bottom front of the case the better).
.bh.
"Our freedom depends on five boxes: soap, ballot, witness, jury; and, when all else fails, Ammo. " ?author?
zepper is offline   Reply With Quote
Old February 4th, 2008, 07:43 PM     #7 (permalink)
Did you look at my case penguin friend? It has a side vent over the CPU which I can see dust going into. However, I'm going to mount 2 80mm fans in front, and according to newegg specs, they draw in more air than my other to fans put out. Is a PSU fan considered an exhaust fan? Air coming out of my PSU is hotter than air coming out of my case, which doesn't feel hot to me at all, and neither does it to my temperature gauge.
Old February 4th, 2008, 08:34 PM     #8 (permalink)
JPMiller's Avatar
My question is WHY you think you need to add what will amount to much more noise for very little benefit, when you state that you dont seem to have a heat issue?
If your just doing it because you can, then its a waste
There are much better ways to improve airflow AND reduce noise
Remove the "punched hole" fan guard from the rear and top fans and you will reduce noise and greatly improve airflow at the same time
A tin snips or dremel, and a few minutes will accomplish much more than what you suggest
Youd also get more from adding an 80mm fan to replace that useless vent on the side
And those 80mm Aspire fanguards are a joke
I would replace those automatically...
Try something like these instead...
http://www.directron.com/3dfg80b.html
http://www.svc.com/svg80bio-jb.html
http://www.svc.com/80lacutaldrg.html
http://www.directron.com/biohazard80.html
Old February 4th, 2008, 09:25 PM     #9 (permalink)
I have a heat issue with my GPU, I think.
The fanguards probably knock airflow to shit, but they look kickass. Also, are you saying that if I put fans there they won't suck in any airs? Fans cost $1.89 a piece.
If I were me, and I am, I'd superglue the fan to the vent on the side.
Old February 6th, 2008, 02:48 PM     #10 (permalink)
JPMiller's Avatar
Ah so "kickassedness" prevails over heat issue....OK
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
GA-M57SLI-S4 CPU FAN BLINC Motherboards 8 January 25th, 2008 11:41 PM
Whats the best fan speed to set to for 8800GT? heero78 Graphics Cards and Displays 1 January 8th, 2008 03:59 PM
New build needs a good but inexpensive fan & heatsink Mercenary Dragon General Tech Discussion 2 January 2nd, 2008 08:37 PM
Is It Just Me? (421)
Test email notifications (28)
Misery Loves Company... (1825)
UPGRADING C/D DRIVE TO 250GB & .. (6)
1 internet. 1 house. 3 computer. ho.. (5)
Multiple video cards? (6)
Folderchat: The Holiday thread (102)
Netbook recommendations? (2)
How to modularize CSS menus (1)
Newegg got pwned (0)
router problem (0)
F.E.A.R. 2: Project Origin (0)
UPGRADING C/D DRIVE TO 250GB &a.. (6)
query. |topic from beginner. |W.. (0)
Need to retrieve files from a v.. (0)
Connected to LAN but unable to .. (4)
FS: Dell 6000 laptop, modded 36.. (1)
