Yes, it may be a little longer than the stock one, and the orientation may be backwards from the one you have now, but those models do fit standard ATX PSU's
Good choice, I couldnt find anything better from that site
really the easiest way is to unscrew the old one, screw in the new one. Then for every old wire you take off, you replace it right away with a new wire. That ensures you don't miss any. Make sure you plug the 6pin PCI-E power connector to the new graphics card too.
Good luck!
