Join TechIMO for Free!
Thread Tools
Currently Active Users: 1421
Discussions: 186,595, Posts: 2,226,940, Members: 230,224
Old June 16th, 2008, 04:14 PM   Digg it!   #1 (permalink)
Please Help! LED IR Array
I am trying to build a LED IR Array for a infrared camera for my comp ( I couldnt find a good forum for this so i just put it in here)
I am having trouble getting the right resistors for the project. I am using 12 volts because thats the only battery pack i could find and i am using 940 high intensity LEDs with a 1.28 voltage drop, they run on 29 mA and I am usign 10 of them
__________________________________________________ ______
This is what it gives me on the Resistor calculator
+12V
18Ω
GND
390Ω
The pic is kinda distorted sorry
  • You will need 1 x 18 ohms 1/8 watt and 1 x 390 ohms 1/2 watt resistors.
  • The 18 ohms resistor is color coded: Brown, Gray, Black, Gold.
  • The 390 ohms resistor is color coded: Orange, White, Brown, Gold.
  • Each 18 ohms resistor consumes 15.138 milliwatt.
  • Each 390 ohms resistor consumes 327.99 milliwatt.
  • Total power consumed by the resistors is 343.128 milliwatt.
  • Total power consumed by the LEDs is 371.2 milliwatt.
  • Total power consumed by the circuit is 714.328 milliwatt.
  • Total current drawn by the circuit is 58 milliampere.
  • The resistor values are calculated based on the common ±5% tolerance resistors.
  • Make sure to wire the LEDs in the correct direction as shown below.
  • Always leave some space for the resistors to breathe. They might get hot.
LED Calculator - Current limiting resistor calculator for LED arrays
__________________________________________________ _______________
So really i need help finding the resistors cause i cannot find the right ones.
eldeablo is offline   Reply With Quote
FREE instant scan
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
3 X 3 Integer array VB redfoxstorm Webmastering and Programming 22 October 26th, 2008 10:04 AM
Cloning to an array Blitzkreig75 Storage Related 3 September 14th, 2006 05:28 PM
detecting array zero tolerance Technical Support 1 April 24th, 2005 12:43 AM
Question on array hongrn Applications and Operating Systems 5 March 1st, 2004 11:18 PM
Modded my PWR led on my case.. next up is my HDD Act. led. WBRchris PC Modification 9 March 25th, 2002 06:41 PM
Is It Just Me? (497)
Misery Loves Company... (1848)
heatsink issue (9)
Word Association!! (1655)
SSD's, RAID, and External Backup (6)
New Mobo (18)
1 internet. 1 house. 3 computer. ho.. (12)
Programming question (3)
Ubuntu or Xubuntu....anyone!!? (7)
A+ Certification; what should I.. (14)
Norton 360 2.0 (5)
How do I burn a .img file? (93)
Confused about graphics card / .. (0)
PCI e slot in a Gateway GT5228 .. (3)
3dmark 01 with Winxp SP3 (1)
DFI socket 939 board acting up (1)
FS: New Benny Hill Megaset DVD .. (6)
