Join TechIMO for Free!
Currently Active Users: 2438
Discussions: 182,452, Posts: 2,180,097, Members: 225,220
Old July 18th, 2008, 09:25 AM   Digg it!   #1 (permalink)
CPU Fan help
On my new computer the CPU fan is the loudest component on my computer and it is a bit of a shame with the other quiet components.
I have a AMD Athlon 64 X2 Dual Core Processor 4400+
Will any of these fans be suitable (and fit) and which one should I get?
Web-Systems Online
protojo is offline   Reply With Quote
Old July 18th, 2008, 09:42 AM     #2 (permalink)
Send a message via AIM to etnietering
Well according to Wikipedia your CPU could either be socket 939 or socket AM2, so you need to look for a cooler that is compatible with both. This one is: Web-Systems Online however, Thermaltake is known for sometimes sacrificing noise for performance (cools well, but you can hear it a mile away).
What you really want is one like this: Arctic Cooling Freezer 64 PRO PWM - Aria Technology My friend had one similar (for a P4 though) and you had to put your ear on it to hear it.
etnietering is offline   Reply With Quote
Old July 18th, 2008, 10:25 AM     #3 (permalink)
Thanks for the quick reply. But will these fit? I measured my fan and it is 7x7cm not including where it is connected. These fans are a bit over.
Old July 18th, 2008, 10:28 AM     #4 (permalink)
They say that they have the proper mounting hardware, and as long as your case is big enough, it will fit. A regular tower enclosure should be big enough. This site has a lot more into about the Arctic Cooling one: Newegg.com - ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler - CPU Fans & Heatsinks
Old July 18th, 2008, 10:43 AM     #5 (permalink)
Well I have this green plastic thing mounted to one side of my casing to capture all the air and make sure it goes out the vent. I measured it up and the thermaltake one should just fit without touching it (it is too wide to fit in it). However looking at the dimensions of the arctic cooling one it wont fit. So I think I'll go for the thermaltake one. I'm sure it will be quieter than the one which I currently have.
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Cpu Fan hungrywhywait Motherboards 3 November 20th, 2006 04:36 AM
Fan behind cpu? kantlivelong PC Modification 12 September 8th, 2004 08:23 PM
What CPU fan is better? Rand Dusing PC Modification 4 November 23rd, 2003 06:17 PM
CPU Fan localboy2332 Technical Support 3 January 9th, 2003 03:28 PM
what CPU fan should i be using? aznlurkerz General Tech Discussion 21 January 3rd, 2002 05:50 PM
