Join TechIMO for Free!
Thread Tools
Currently Active Users: 1420
Discussions: 186,596, Posts: 2,226,943, Members: 230,226
Old July 28th, 2008, 08:35 PM   Digg it!   #1 (permalink)
Question
120mm Fan Direction?
Hello folks
Was wandering if you guys could give me a hand with a simple question.
On the side of my case I have an opening which allows a 80mm fan to be connected, however I have replaced this with a bracket which allows a 120mm fan to be connected (80 to 120 converter plastic) and the next step is getting a fan to put on. (Wanted to check first with a cheap bracket before getting the fan)
As pictured in the image, you can see by my superior MS Paint skills that im a little confused in which way the fan should blow air on the side of the case. The CPU fan blows air onto the board, so would it be a good idea to have the air blowing inwards from the side of the case?
Or would that destroy the flow of air coming from the front, so would it be a better idea to have the air blowing from the inside out on the side?
Pencheven is offline   Reply With Quote
FREE instant scan
Old July 28th, 2008, 09:13 PM     #2 (permalink)
JPMiller's Avatar
For correct airflow, the fan should be blowing cool air from outside the case inward (not outward)
Old July 28th, 2008, 11:35 PM     #3 (permalink)
Thank you for your quick reply
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Processorīs Fan direction borracho79 General Tech Discussion 3 April 27th, 2005 01:56 PM
heatsink fan direction? ajna_star General Tech Discussion 4 July 23rd, 2004 04:57 PM
Changing fan direction? kantlivelong PC Modification 15 September 19th, 2003 04:34 PM
cpu fan direction????? Gait_Keeper Processors, Memory, and Overclocking 5 July 6th, 2003 11:24 PM
CPU fan direction joker_927 General Tech Discussion 11 January 5th, 2003 03:44 AM
Is It Just Me? (497)
Misery Loves Company... (1848)
heatsink issue (9)
Word Association!! (1655)
New Mobo (18)
SSD's, RAID, and External Backup (6)
1 internet. 1 house. 3 computer. ho.. (12)
PC to LCD : DVI to VGA problem (1)
how to break windows firewall (0)
Programming question (3)
Ubuntu or Xubuntu....anyone!!? (7)
A+ Certification; what should I.. (14)
Norton 360 2.0 (5)
How do I burn a .img file? (93)
Confused about graphics card / .. (0)
PCI e slot in a Gateway GT5228 .. (3)
FS: New Benny Hill Megaset DVD .. (6)
