help build gaming pc  | | |
August 17th, 2008, 09:02 PM
| Hi I am looking to spend between $700 and $800
I think I need the most help on the motherboard, case, and power supply.
This will be my first PC build so please give me tips and good alternatives to anything I list.
Mother board Asus P5N-D Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131232
I'm looking for stable, overclockable, and 2x16 PCI express slots. (in case i go 2xvideo cards in the future)
Video Card
Geforce 9800 GTX Newegg.com - GeForce 9800 GTX+, GeForce 9 series, Desktop Graphics / Video Cards, Video Cards & Video Devices, Computer Hardware
Ram
2 sticks of 2 gigs OCZ SLI-Ready Dual Channel 4096MB PC6400 DDR2 800MHz Memory (2x2048MB) OCZ2N800SR4GK at TigerDirect.com
CPU
Intel Core 2 Quad Q6600 Quad Newegg.com - Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Processors - Desktops Case
I am pretty open here I looked through about a hundred of these, looking for a good case for no more than $100
(will be over clocking so looking for one with good air flow)
Power supply
Again pretty open. I'm thinking something like 500W and around $100
Hard drive
I have an older 200gig HD, any suggestions here? Should I just keep it? |
August 17th, 2008, 09:05 PM
It might be worth getting a bigger psu as it would make your pc more 'future proof'. I have a 650 watt psu and i'm struggling with it. |
August 17th, 2008, 09:32 PM
look for a case without any major flaws (look at reviews). It's more something for you to pick out. Cases are just as much about style as performance. What are the specs of your HD. It's got to be over 5400 RPM to be acceptable. Power supply- go with any good brand (corsair, coolermaster, OCZ, etc.) 600+ watt power supply. Stay around $100 as that insures good amperrage. |
August 17th, 2008, 09:44 PM
| | SoMuchAnime-SoLittleTime
As for that ram, if you want to get it, buy it NOW. I wish I could use more ram as I'd pick that up, but I've maxed out my desktop.
It will not last long at that price.
I would get a 4850, pretty much even or better than a 9800 GTX but only costs $150 or so. |
August 17th, 2008, 09:49 PM
| | \m/(°-°)\m/
August 17th, 2008, 10:05 PM
August 17th, 2008, 10:25 PM
| | \m/(°-°)\m/
August 18th, 2008, 12:07 AM
Thanks for the info, that OCZ gamexstream psu mentioned sounds good I think I'll get that.
The HD is 7200 but I may but the one KarmaKiller mentioned.
Now the war between the 9800 gtx and the 4850... they sound pretty even with some price difference, I guess its just what type you prefer.
What about the motherboard, think the one I picked will do the job? |
August 18th, 2008, 12:24 AM
| | \m/(°-°)\m/
Yeah, that's a nice Mobo IMO.
And really, just get whatever GPU is cheaper, since they perform about the same. |
August 18th, 2008, 03:49 AM
I'd still switch to getting a 4850 regardless of those specific benchmarks since I've seen more benchmarks that go in favor of the 4850.
Huh
