Join TechIMO for Free!
Thread Tools
Currently Active Users: 1420
Discussions: 186,596, Posts: 2,226,943, Members: 230,226
Old September 17th, 2008, 01:58 AM   Digg it!   #1 (permalink)
Fizur2002's Avatar
need help with future mod
i need someones help with a simple mod for my future case, CM 690. I will be painting it a hammered gunmetal gray with black trim. But i was wanting to stencil my name onto the side of the case. Would anyone be willing to assist me in creating a font and lettering that i can cut out of cardboard so i can do this? Name i will be using will be FrostByte
Originally Posted by pullmyfoot View Post
Aha. Well that was a waste of time I feel quite stupid now
Originally Posted by Figgey View Post
haha sorry, I'm still a newbie at most of this.
Originally Posted by Tech Report
—well beyond the threshold of pain. This mofo will burn you.
Fizur2002 is offline   Reply With Quote
FREE instant scan
Old September 17th, 2008, 06:08 AM     #2 (permalink)
Fizur2002's Avatar
i also need to know where i can find sata headers so i can create custom power cables for my HDD's and Optical drives.
Old September 17th, 2008, 08:08 AM     #3 (permalink)
Folding@home since 1862!
KarmaKiller's Avatar
Sata headers:
Sata Connectors | Page 1 | Sort By: Product Title A-Z - FrozenCPU.com *
As far as the paint, I suck at painting. But I can offer an idea though.
Print out the style of the name on some sticky printing paper, cut it out and use it for a stencil then spray over that.
That's about the only idea I can think of.
MainRig: Q6600@4Ghz |EVGA 780i |EVGA 9800GX2 |4Gigs Tracers|
|WD640Gb | OCZ 600w |ApogeeGT- LaingD5- Black Ice 240mm
Folding FAQ's-Fold for Team 111-Stats
Old September 17th, 2008, 08:11 AM     #4 (permalink)
Fizur2002's Avatar
are you any good with creating letters and such in photoshop so i can do a printout of it?
Old September 17th, 2008, 08:15 AM     #5 (permalink)
I'm horrible with photo editing.. I know there are some Guru's though on here. Really what I would do is start looking into fonts. Surely you can find a font that has the style your looking for.
If not I know ShuckyD has a crap load of fonts. Maybe send him a message and see if he's willing to help.
Old September 17th, 2008, 09:39 AM     #6 (permalink)
Mobile Member
ShuckyD's Avatar
I'm here, found the thread
Hi KK!!
Hint: For a gunmetal/hammered look Rustoleum makes a pretty neat spray paint that I have used a couple times. It's under their "hammered" lineup and you can get it in both spray and can. I used the can most recently since I redid the tow-bar on my truck. (sanded down and repainted w/ this stuff). Also another neat thing is the stuff in the can was pretty thick, it was like brushing on epoxy
Thinkpad T61 14.1 wide | WinXP Pro | Intel C2D T8300 2.4ghz CPU | 3GB DDR2
AGN WiFi, BT, WWAN | 256mb NVS140 graphics | 160GB 7200RPM HDD
ShuckyD is offline   Reply With Quote
Old September 17th, 2008, 12:02 PM     #7 (permalink)
zepper's Avatar
Lightbulb
Nevermind, sorry...
"Our freedom depends on five boxes: soap, ballot, witness, jury; and, when all else fails, Ammo. " ?author?
zepper is offline   Reply With Quote
Old September 17th, 2008, 02:20 PM     #8 (permalink)
JPMiller's Avatar
Zepper clicked on the wrong thread I think...
Another option to consider, is to NOT use a stencil or paint for the lettering...
Instead buy a decently thick sheet of plexiglass from a local hardware shop...
Find a cool font, print it out and then trace it on the plexi... cut it out and then use sandpaper or some other effect to create that "frosted" effect like ice
You may even use a blue LED to make it look even chillier
Another option to sanding or "etching" would be to go to a local Hobby Shop and purchase either a spray on or sponge on "frosting" product
Buy DELTA PermEnamel White Frost | Supplies | Kits | Online Discount Store
Old September 17th, 2008, 07:18 PM     #9 (permalink)
Fizur2002's Avatar
nice
Old October 1st, 2008, 10:24 PM     #10 (permalink)
Mobile Member
ShuckyD's Avatar
Heres a shot at the "Frostbyte" look... I took this from a light blue color and did a "find edges" effect on it in photoshop. I also dropped a shadow on it so that its easier to see on the screen. If there is something else you would like to see, like it in a color and then beveled, etc. let me know, I have it here as a .PSD i can edit.
Fizur2002, if you want to use this (or similar) to trace I can go through in Photoshop and clean up alot of the excess stuff on the letters that would make it almost impossible to trace successfully.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
help me w/ my future iwannakno Certification and Education 2 July 1st, 2006 01:43 PM
PC of the future! Bizkitkid2001 General Tech Discussion 9 November 24th, 2004 03:24 PM
I need a mod any mod to contact me. gentry_joey IMO Community 19 October 17th, 2004 01:36 AM
Mod supplies site/mod Urban_Squrill PC Modification 4 August 12th, 2003 08:17 PM
My first mod (hdd mod) SokkaDiSokk PC Modification 18 August 15th, 2002 04:45 PM
Is It Just Me? (497)
Misery Loves Company... (1848)
heatsink issue (9)
Word Association!! (1655)
New Mobo (18)
SSD's, RAID, and External Backup (6)
1 internet. 1 house. 3 computer. ho.. (12)
PC to LCD : DVI to VGA problem (1)
how to break windows firewall (0)
Programming question (3)
Ubuntu or Xubuntu....anyone!!? (7)
A+ Certification; what should I.. (14)
Norton 360 2.0 (5)
How do I burn a .img file? (93)
Confused about graphics card / .. (0)
PCI e slot in a Gateway GT5228 .. (3)
FS: New Benny Hill Megaset DVD .. (6)
