Thoughts on PC Build
Currently Active Users: 1970
Discussions: 200,950, Posts: 2,379,436, Members: 246,311
Old April 2nd, 2009, 02:45 PM   Digg it!   #1 (permalink)
I am looking to pull the trigger on the system below but would like feedback, if available.
I am not a "hard" core gamer but want the system to have some flexibility. I play WOW 90% of the time and not much else. I do want the ability to run multiple programs (nothing like video editing) while playing a game so that went into my choices.
Any feedback is appreciated. The entire build below is coming out at around $1,200 with tax & shipping and I think is pretty decent for what I am getting. Not including software as I am using XP Pro (already own). The system is being built to upgrade to WIN 7 in the future.
I am not "sold" on the ANTEC 900 case yet. I am going to look at a buddies tonight to check it out. I want a very quiet case with good cooling (and a top fan for venting). The ANTEC seems to be the best rated for those needs.
Motherboard: - GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX
Processor: - AMD Phenom 9950 Agena 2.6GHz Socket AM2+ 125W Quad-Core Black Edition
RAM: - 4GB - Corsair (PC 8500) (2 x 2gb) Dual Channel
Video Card - EVGA 01G-P3-N981-TR GeForce 9800 GT 1GB 256-bit GDDR3 PCI Express 2.0
Sound: On board - 8 channel
Hard Drive - Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive
DVD Rom - ASUS 22X DVD Burner with LightScribe Black SATA Model DRW-22B1LT
Network - On board Gigabit
Wireless - TRENDnet TEW-623PI 32-Bit PCI Rev. 2.1/2.2/2.3 Wireless N-Draft Adapter
Case - ANTEC 900
Power Supply - BFG Tech GS-550 550W ATX12V V2.2 / EPS12V V2.8
Monitor(s) - QTY 2 - Acer V223-WBD 22" Widescreen TFT LCD Monitor (Black)
gpascal is offline   Reply With Quote
Old April 15th, 2009, 07:14 PM     #2 (permalink)
glendalf81's Avatar
just a quick piece of info for you, xp cannot be installed on SATA HDD'S as it does not have any SATA drivers built into it unless you have the SATA drivers for your mobo on a floppy in which case you will need to hit the option to install a third party raid driver during the install, and of course you will need a floppy drive in your new machine
alternatively you can build the SATA drivers into an xp install disc which is a bit tricky but google "installing xp to SATA" it will bring up a few sites which explain how to do this
glendalf81 is offline   Reply With Quote
Old April 15th, 2009, 07:17 PM     #3 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
^That is untrue.
I just got reinstalling my OS (XP Pro SP3) on my sata HDDs no issue.
I have no idea what your talking about. I've installed XP hundreds of times on SATA HDDs without installing drivers.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old April 15th, 2009, 07:57 PM     #4 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
Its probably a bit late since this thread is a couple weeks old but IMO I'd skip the AMD build altogether and go Intel. For not much more in cost you would have a better foundation. Even if you did stick with the AMD system I'd throw a little more money out there and get one of the new CPU's. You could skip the Antec 900 go with the 300 for $50 less and add that cost to either the GPU or better CPU and you'd be far better off.
On a bit of a side note, I don't see any mention of an aftermarket cooler or overclocking. If you aren't a heavy gamer and aren't OC'ing you could also save a little cash and go with a more budget minded motherboard. You might only shave $20-30 but again that could be spent on a better CPU, more memory or other peripherals.
Linus Torvalds
RicheemxX is online now   Reply With Quote
Old April 22nd, 2009, 10:37 PM     #5 (permalink)
Send a message via AIM to darkertint Send a message via Yahoo to darkertint
You only need to worry about Sata drivers on older motherboards. My new gigabyte motherboard for my i7 installs xp without having to install any third party drivers. I would also go with intel over amd... my new i7 is blazing fast and with the stock fan i had 8 cores running at 3.5ghz. My whole system was only $1000 and that was for an i7, 3gb ddr3, 9800gt, dvd burner, 1tb hard drive
I7 920@3.7Ghz// 6GB DDR3 // Geforce 9800GT
Use your PC's idle time to help cure Cancer, AIDs, ++
http://www.worldcommunitygrid.org/
darkertint is offline   Reply With Quote
Old April 23rd, 2009, 12:07 AM     #6 (permalink)
it looks ok but if its 90% Wow i wouklld go for a cheaper build, but well i know after you get this youll be goigninto many other games
another thing. for 1200 you coulddo an i7 920 build.
much better IMO
for cases try: NZXT Tempest
best ventillation out there, the best in my opinion for mid-towers
much better than antec 900
adrumm is offline   Reply With Quote
Old April 23rd, 2009, 12:08 AM     #7 (permalink)
oh an go for ddr3 and the EVGA gtx 260 core 216 55nm
Old April 23rd, 2009, 10:18 PM     #8 (permalink)
cksboy15's Avatar
Send a message via Yahoo to cksboy15
This thread pretty much died long before you posted. Even then the i7 can only be used with ddr3 at the moment.
cksboy15 is offline   Reply With Quote
Old April 23rd, 2009, 11:27 PM     #9 (permalink)
huh?
Old April 25th, 2009, 12:16 AM     #10 (permalink)
cksboy15's Avatar
thread started april 2nd and wasn't posted in till the 15th then darkertint posted on the 24th and you followed suit.
New Build Thoughts The Real Bingo General Tech Discussion 7 March 23rd, 2009 02:18 PM
my first build... any thoughts? m_shynoda General Tech Discussion 5 July 7th, 2008 03:19 AM
Any thoughts on this first build?? zman64 Motherboards 3 March 7th, 2008 03:10 PM
My first PC build.. Any thoughts?? gigercom Motherboards 4 March 4th, 2007 10:15 PM
New Build..thoughts? Hollowpoint General Tech Discussion 38 January 30th, 2006 12:50 AM
The disrespect of Obama by Russian .. (33)
Making Health Care Worse (176)
Is It Just Me? (2940)
Regular Build (7)
Print spooler problem (15)
Regular Build (7)
How to convert MP3's (4)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Open With ..... Win7 (0)
java code for fibonacci (1)
