Results 1 to 4 of 4
Thread: Quiet Fans
    May 2002
    Georgia
    13
    Quiet Fans
    I need some suggestions on a quiet but efficent 80mm fan. Also, are fan filters worth it? Do they really reduce dust?
    Welcome to TechIMO. I hope you enjoy your stay. While you are here, to cut down on confusion, please only create one thread per topic.
    Dave
    FAQ
    Ultimate Member FalcomPSX's Avatar
    SoCal.
    2,855
    no need to double post...
    Enermax makes adjustable fans that are either quiet or loud dependong on how you set them, good fans. filters are a mixed blessing, they keep dust out of your systemsomewhat, but they also need cleaning themselves...so it's a judgement call I'd say. I dont' use them.
    FalcomPSX
    Indispensable Member surreal's Avatar
    Meechigan
    30,887
    Regarding filters, yes you have to clean them, but you sure see the dirt build up, which you don't if you have a closed case.
    So you could end up keeping them cleaner than you would the case..
    Mar 2002
    85
    I bought vantec stealth fans from http://jab-tech.com/vantec_stealth_fans.html
    I bought two to use as exhaust fans ... They are dealy quiet. I also have filters which do reduce airflow and do have to be cleaned. If you have a window in your PC you need to have filters on all intake fans (IMO)
