14cm fans  | | |
May 3rd, 2009, 02:47 PM
hi, basically i bought a new case recently and will be arriving in a few days, its a 690 dominator nvidia edition and it supports 14cm fans. some people say it can support 3x 14cm some say something else etc... anyone know what fans it can have? also where would i be able to get 14cm fans? i am in the uk so i can't use newegg unfortunately.
thanks in advance |
May 3rd, 2009, 03:00 PM
May 3rd, 2009, 03:03 PM
Looks like the only 140mm fans that you can use are for the top blow-hole. Cooler Master - Ultimate provider of Computer Chassis | Cooler | Power Supply Quote:
Cooling System:
Front :120mm green LED fan x 1, 1200 rpm, 21 dBA,
Rear : 120mm standard fan x 1, 1200 rpm, 21 dBA,
Top : 120 or 140mm fan x 2 (optional),
Bottom : 120mm fan x 1 (optional),
Left: 120mm standard fan x 1, 1200 rpm, 21 dBA,
Right: one 80x15mm fan (optional)
__________________ Rest peacefully little furry beast |
May 3rd, 2009, 03:20 PM
I found this pic showing it can have 3x 14cm fans. |
May 3rd, 2009, 03:45 PM
| | Instigator
As been pointed out before, the Cooler Master NV 690 supports only 2x 140mm fans that can be located at the top of the case. The remainder of the fans are all 120mm.
May 3rd, 2009, 03:51 PM
May 3rd, 2009, 04:23 PM
| | Instigator
May 3rd, 2009, 05:42 PM
| | \m/(°-°)\m/
I'm pretty sure the bottom fan hole can support a 140mm fan (or 14cm)
When I had my 120mm fan in the bottom of mine, it had 4 larger screw holes besides the 120mm mounts.
That said, you should just get 120mm fans. There is hardly any difference between the 2. There are far more options in the 120mm field then the 140mm field. And they are cheaper too.
Just my two. |
May 3rd, 2009, 08:01 PM
The regular 690 can support a good number of 140mm and most locations can accept 120s instead. The diagram of the NV version should help. Not sure which are the good 140s., but I think there is at least one version by Yate Loon out there now. The idea is that you can get more air at the same or lower noise by using the 140s.
.bh.
May 4th, 2009, 05:03 AM
ok so i wont bother getting 14cm fans so what 12cm fans should i get? i will need 1 for the bottom and 2 for my rad. originally i was planning to have my rad outside of the case but now there is a space available!!
edit
i am planning to have a Black IceŽ GTS-Lite 240 Black radiator (needs 2 fans)
and a Laing DDC1+ Ultra Pump : DDC-PlusT pump.
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | the fans go where? | ck_psy | Motherboards | 2 | April 20th, 2005 02:41 AM | | Fans and such | jml90 | General Tech Discussion | 2 | September 26th, 2004 01:25 AM | | fans | spilot | General Tech Discussion | 7 | April 29th, 2004 03:19 PM | | Fans | embj | General Tech Discussion | 17 | May 29th, 2003 10:56 AM | | NBA Fans, or fans of Shaq.. | Makaveli | IMO Community | 23 | January 15th, 2002 05:03 PM | |
