help w/ my pc upgrade..bottleneck issues
Currently Active Users: 2364
Discussions: 200,944, Posts: 2,379,338, Members: 246,306
Old May 22nd, 2009, 10:32 AM   Digg it!   #1 (permalink)
hi to the very helpful guys here in techimo. im back again w/ another question
im considering to upgrade my current computer. my current specs is the following
Athlon 64 x2 7750@ 3.2ghz
asus m2n68-am (am2+Hypertransport 1.0 and PCI-E 16x)
2x2gb team xtreem rams
WD 500gb 16mb cache
Palit HD4870 1gb ddr5 dual ed.@turbo mode
my 3dmark score is 12100. as you can see its low if you consider my graphics card being a HD4870 and its at turbo mode(factory OC switch for palit) and my procie is overclocked at 3.2ghz (from 2.7) im wondering if what is the cause of my bottleneck. im planning to upgrade my procie (pref. phenom II 3x 720) or a gigabyte am2+ mobo hypertrasport 3 pcie-2.0 GIGABYTE - Product - Motherboard - Overview - GA-MA780G-UD3H (rev .1.0) apparently my curent mobo (asus m2n68-am) supports the phenom II procie that im planning to upgrade, im guessing it wont work on its full potential on my mobo, hopefully not
im wonderin what should i upgrade first. my mobo or my procie? and which upgrade would increase the performance of my pc(3dmark score) thanks a bunch guys
Phenom II 955, 2gb kingston ddr3, Gigabyte GA-MA790FXT-UD5P AM3, 2x WD 500gb SATAII 16mb cache, Palit Radeon HD4870 1gb dual edition@crossfire, LG dvd writer lightscribe, HEC Cougar 700w PSU, modded gigabyte poseidon atx, G Power II cpu cooling running on Windows Vista Ultimate SP 1
jprovido is offline   Reply With Quote
Upgrade processor to stop bottleneck Burts Processors, Memory, and Overclocking 16 February 6th, 2009 07:16 AM
Name that bottleneck! joker_927 General Gaming Discussion 15 January 22nd, 2005 05:05 PM
Nagging software conflict issues...should one upgrade or not? John Prophet IMO Community 1 January 16th, 2005 01:05 AM
WinXP, Registration, Upgrade Issues fufiter9246 Applications and Operating Systems 3 June 2nd, 2003 11:42 AM
Compaq P1 upgrade issues JacobM5727 Technical Support 6 September 21st, 2002 01:39 AM
Making Health Care Worse (162)
The disrespect of Obama by Russian .. (15)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (0)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
