May 30th, 2002, 12:17 PM
| 4 pin molex to 3 pin "female" I got a digi doc 5 to control and moniter and control my case fans. The fans for the proc, chipset, mem, and vid card are all 3 pin fans. So those are set. The problem is that my 3 case fans are 4 pin molex.
I looked everywhere including newegg, sotrickcomputers, mwave, etc. All the 3 pin to 4 pin molex adapters are 3 pin "male" to 4 pin molex.
Where can I get a 4 pin molex to 3 pin "female"? How hard is it to make my own. I bought a solder gun for another project.
I guess I could break down and buy 3 case fans that use 3 pin adapters.
Thanks guys. |
May 30th, 2002, 12:20 PM
| What are you trying to plug from what to what?
I just got a couple Thermaltake 60mm fans that were three pin fans with adapters so you could plug them into 4-pin Molex (drive power) connectors....
There are only 10 types of people that understand binary.....
May 30th, 2002, 12:23 PM
| I got 4 pin molex fans. They need to plug into a 3 pin connector. Basicly I need to convert my 4 pin into a 3 pin (female) just like your fans.
All the 4 to 3 pin adapters i found convert to the wrong 3 pin (male). |
May 30th, 2002, 12:28 PM
| Hmmmm... I don't have any ideas one where to BUY something like that, but you could just wire up the +/- to the +/- of a 3 pin fan connector (you could cut off from an old 3-pin fan). Just disregard the SENSE/RPM line though. |
June 24th, 2008, 04:14 AM
June 24th, 2008, 04:15 AM
June 24th, 2008, 02:43 PM
| WOW Necro-Thread Revival Award of The day Goes to pabad09...
6 PLUS YEARS OLD...
registered & joined the forums just to earn the award I suspect?
(How in gods name do you people pick & choose these old threads to revive? I mean you couldn't of been looking to ASK a question or find an answer to one, since your post is simply providing a link to a thread as "suggestion" or for help... which makes one wonder, is that the limit of your Computing knowledge? a 4 pin to 3 pin wire adapter?  ) |
July 5th, 2008, 02:35 PM
| Hey you can google this forum so its not so difficult to fin this thread if you search for this. And I was actually searching right now for this adapter with any sucess until now. So it is not really sensless to solve this problems after years because many other peolple with this specifiq problem can profit by this. So thanxs pabad09! |
