Comuter Cooling
Currently Active Users: 1923
Discussions: 204,475, Posts: 2,418,934, Members: 249,895
Old June 15th, 2009, 11:43 PM   Digg it!   #1 (permalink)
Comuter Cooling
Hi.I want to know about computer cooling.I have Dual Core 3.2 Ghz and Nvidia 9600 GT Graphic Card.So after some time my computer gets heated and the processor fan give loud sounds.I have currently 2 Cooling fans which i can fit in the casing.My powersupply also have two fans.
I want to know that what should i do to prevent my computer from heating and where and in which direction i should fix these cooling fans so they can prevent computer from heating.
Thanks !
muz_501 is offline   Reply With Quote
Old June 15th, 2009, 11:46 PM     #2 (permalink)
Wolfegang16's Avatar
How hot does your CPU and GPU get ?
I have my case set up that:
front two fans are intake fans
Side fan is exhaust
rear fan is exhaust
and top fan is exhaust
You could maybe think about getting a new CPU fan.. how old is yours ? is it stock?
PhenomIIX4 940@3.7GHz -- GTX260@735/1625/1275 -- 4Gig Gskill@5-5-5-15/1066
My PC
Wolfegang16 is offline   Reply With Quote
Old June 16th, 2009, 12:31 AM     #3 (permalink)
Flying JJ's Avatar
Send a message via MSN to Flying JJ Send a message via Yahoo to Flying JJ Send a message via Skype™ to Flying JJ
Naturally heat will rise, why fight it.
Air in through the bottom, out at the top.
Most go with air in the front, out the rear so they don't have the hot exhaust hitting them.
As I just found out with mine, watch for stagnant air pockets! I had a swirl just above my GPU's and below my CPU cooler. I was causing a 10-15C diffrence in air temp. right in that area. Put a fan internal to break it up.
Wire management is also pretty important for good air flow.
My theory, you can never have too many fans!!!!!
11 and counting on mine. And no it really isn't that loud.
Vi per Concordiam
Flying JJ is offline   Reply With Quote
Old June 16th, 2009, 12:41 AM     #4 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
A bit OT here but how did you test for stagnant air??
And IMO too many fans can actually cause as much of a problem as not enough. I'd rather have a great cooler and a couple good fans than have it be overkill.
RicheemxX is offline   Reply With Quote
Old June 16th, 2009, 01:06 AM     #5 (permalink)
PC Upgrade Procrastinator
ShyguyXPC's Avatar
true, too many fans can create too much turbulence and non uniform airflow through the case, but depending on where their mounted.
the other issue is balancing the intake and exhaust air flow volumes, with many "breathable" case designs these days its not that much of an issue (cases with mesh front and side/top panels, etc), but for solid panel case designs it can be an issue.
as was said above cable management is also a good thing to look into, tuck cables away out of airflow paths, etc, as these can create air pockets as JJ described above, either where air is stuck, or even turbulence or vortices of warm air that isn't being exhausted. even rounded cables will cause this, so its best to try and bundle excess cables with others and tuck out of the way, etc. but depending on the case, components, etc, it can be difficult and each users PC will be different in general with cable management. some can get a really clean look, others only partially. as they say, "Your Miles May Vary".
But wondering what case does the Original Poster have?
using stock CPU cooler or aftermarket cooler?
which Dual Core CPU is it?
Intel, AMD?
Intel Pentium D, Dual Core, Core 2 Duo, Celeron Dual Core, Xeon?
AMD Athlon 64 X2, X2, BE X2, Opteron, etc etc?
Stock speed? Overclocked?
Brand and Model of Power Supply?
post current CPU, GPU and Chipset Temps if possible, Idle and Full Load temps if possible too.
more details needed to offer more than general advice.
i7 920@2.66//MSI X58 Platinum//3GB DDR3 1333//GTX285 680/1476/1250//9800GTX 675/1688/1100//HTO Striker 7.1//Corsair 750TX//Tt Armor//Win7 64//250GB, 2x250GB RAID 0, 500GB, 500GB
Old June 16th, 2009, 02:00 AM     #6 (permalink)
Flying JJ's Avatar
Smoke flow and temp. sensors. Was temp. using the ones from my 2 Scythe fan controlers.
Side of the case is clear. It was funny, I had a 5-10C temp. diffrence within 3 inches.
Should have been more specific, many fans at the right places can control the air very well, most of mine are high cfm but I run them at low speeds=quieter. If needed I can crank them up and make this thing a wind tunnel.
For further clarification, air flow patterns are just as important as flow rate.
I like to use fans where needed, oversize them and then throttle them with a good controler. Flow when needed but quiet for the most part.
Old June 16th, 2009, 02:22 AM     #7 (permalink)
cksboy15's Avatar
Send a message via Yahoo to cksboy15
You forgot the Phenom X2 which you probably put in the "ect" Course you could also count that as a quad core seeing that it has 2 disabled cores on it.
"Does the Walker Choose the Path or the Path the Walker?" Garth Nix in the book Sabriel
cksboy15 is offline   Reply With Quote
Old June 16th, 2009, 02:28 AM     #8 (permalink)
ShyguyXPC's Avatar
yeah, the Phenom II X2 is relatively new and forgot about it, also since I usually associate the "Phenom" name with X3 and X4 chips, I didn't list that, as I was only listing possible Dual Core Chips as per what the OP mentioned.
Old June 23rd, 2009, 02:27 AM     #9 (permalink)
Hi.I am facing a major problem.Dont know what it is.Cooling or Graphic Card ?
My Computer Specifications are:
Intel Pentium D 3.2 Ghz.
80 GB HDD.
1 GB RAM DDR2.
Combo Drive Samsung.
Nvidia Geforce 9600 GT.
No Cooling Fans.
Powersupply with one fan only.
The problem is that when i run any game such as Call of Duty 4,Company of Heroes and The Godfather 2 the computer runs for some time and i can play the game but after 2-3 minutes the computer restarts.When i again play the game the computer restarts again.When i checked the hardware monitoring system just after the restart i noted that :
Processor Fan Speed : 3900
Processor Temp : 88-90 C
Internal Temp : 48-49 C
Remote Temp: 52-53 C
Graphic Card was also very hot
The problem i dont understand is that the computer only restarts when i start the game.If i dont run the game the computer dont restart and keep running.
Actually few days ago i had a 350 W Power supply with 2 Fans but it malfunctioned due to heavy load of the computer and the graphic card as it requires minimum 400 W.It also malfunctioned the supply of the motherboard.But at that time when i had 350 W Power Supply the games ran perfectly with no problems at all.
I repaired the supply of the motherboard and bought a 1 fan 400 W Power Supply.Now i am facing this problem.But note that the computer only restarts when i play the game.When i dont play it runs perfect but the computer gets hot.Again when i run the computer in air conditioner i can play the game for longer time(10 minutes).
I think the problem is with the cooling of my system unit or maybe with the graphic card.Oh Yeah i also removed the graphic card and then played the game company of heroes then the computer didnt restart.I have two cooling fans at the moment but i hae not fixed it in the casing.
I need to know what is the problem with my computer.Please Help !!
This long specifcations are specially for ShyguyPC.But i need advive of all.
CPU Cooling. heatsink/water cooling??? jamhough22 Processors, Memory, and Overclocking 3 July 19th, 2008 08:18 AM
Comuter is rebooting, sent to get fixed but.... TicklesX Technical Support 8 September 14th, 2006 05:39 PM
What Cooling To Get -relk- Processors, Memory, and Overclocking 5 January 7th, 2006 12:06 AM
cooling a p4 sr71000 General Tech Discussion 3 March 30th, 2005 11:18 AM
about cooling sab571 General Tech Discussion 4 August 4th, 2004 01:13 PM
Fighting Utility Companies (10)
Is It Just Me? (1494)
Hi from Sara (13)
Recent Problem (5)
I need help Guess what happened to .. (5)
Can't Rename Files (11)
[ F@H Chat] 03/07/10 New Month New.. (84)
Need some suggestions on building a.. (21)
My PC shutsdown after 30 minutes of.. (5)
Compaq presario V5000 LAN Driver (8)
Drive 0 not found: Serial ATA, Sata.. (6)
Need LG W2343T monitor driver (6)
You Do Not Have Permission to Chang.. (17)
Processor speeds? (17)
would this build be enough for WOW? (4)
Clean up safe to delete? (4)
Where to buy 3Rsystem Iceage 120 Boss.. (3)
Need some suggestions on building a g.. (21)
Recent Problem (5)
2.6.12, Linux kernel (3)
I need help Guess what happened to my.. (5)
[ F@H Chat] 03/07/10 New Month New T.. (84)
Can 2 cards run off 1 pcie 16 slot (2)
Drive 0 not found: Serial ATA, Sata-0 (6)
Microsoft removes hardware virtualiza.. (0)
Hard drive full = slower computer? Is.. (3)
Screen Flickers @ Bios, Waves at Desk.. (0)
Writing lead-out (6)
Broken PaperPort 10 Link (5)
Windows XP Pro Error log (4)
Lost Password - Win7 (8)
YOUR BEST TRICK OR TIP FOR YOUR COMPU.. (19)
Help (1)
Logitech web cam (1)
Replacement hard drive for Dell 600M (16)
audio to you tube (2)
Video card for Dell Dimension E510 (10)
Sony Vaio on Vista - Wont Boot (2)
