Power Problems
Currently Active Users: 1733
Discussions: 200,950, Posts: 2,379,459, Members: 246,312
Old June 29th, 2009, 02:50 PM   Digg it!   #1 (permalink)
Power Problems
Howdy all,
I am attempting to install a "ThermalTake TR2-430W" power supply into my new Intel DG43NB Motherboard. I have connected the 24 pin main power supply and the 4 pin 12V connector and I am getting no results when I connect the power.
Have checked all electrical connections and I seem to have power to the board(small green light on board when power is applied) however the CPU fan is not fanning and nothing else is humming. As I mentioned earlier I only have the 24pin main and the 4pin 12V connectors attached to the board.
Thanks for the help,
Bill
Bill Peters is offline   Reply With Quote
Old June 29th, 2009, 03:39 PM     #2 (permalink)
Flying JJ's Avatar
Send a message via MSN to Flying JJ Send a message via Yahoo to Flying JJ Send a message via Skype™ to Flying JJ
You may also need to connect the "on" button to the board. Do you have the drawing for the board?
Vi per Concordiam
F@H Team 111 TEAM STATS
Flying JJ is online now   Reply With Quote
Old June 29th, 2009, 03:47 PM     #3 (permalink)
Flying JJ's Avatar
Refer to "G" pins 6&8 on the following link page 43. Hopes it helps, let us know either way.
DG43NB Product Guide
Please help! - Power problems I think Iturea Technical Support 8 April 2nd, 2007 12:29 PM
Power-up problems MeLast General Tech Discussion 10 January 29th, 2007 05:40 PM
Power-up problems Aceba$ Technical Support 4 January 9th, 2007 08:34 PM
Power problems? super_gray Technical Support 11 September 26th, 2005 12:45 PM
power problems thekemp Technical Support 3 October 15th, 2002 08:10 PM
The disrespect of Obama by Russian .. (39)
Is It Just Me? (2941)
Making Health Care Worse (177)
Regular Build (7)
Print spooler problem (15)
Dept. of HS: NSA 'Helped' Develop V.. (16)
Internet Lost (3)
Virus advise (7)
EVGA 9800 gtx help with finding a goo.. (10)
Modern Warfare 2: Who Bought It? (62)
Regular Build (7)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
