Basic upgrade question
Currently Active Users: 1477
Discussions: 200,930, Posts: 2,379,155, Members: 246,297
Old September 25th, 2009, 04:52 PM   Digg it!   #1 (permalink)
I have very little knowledge about this sort of stuff, so if it's a stupid question I apologize.
Right now I'm using a computer that has all the specs I need for playing games aside from the graphics card. I have an Intel g45/g43 Express Chipset. Now, I was talking to someone who said it was an integrated chipset, and most things are are integrated can't be upgraded. Do I have to buy a new computer if I want a better Video Card, or is there something I can do?
Thanks!
Mortalis is offline   Reply With Quote
Old September 25th, 2009, 05:07 PM     #2 (permalink)
Aaron_8015's Avatar
Send a message via MSN to Aaron_8015 Send a message via Skype™ to Aaron_8015
Hi and welcome.
If its a desktop then chances are it can be upgraded. If you give us the make and model. We can find out for you.
Q6600//6gb//2x 260GTX//2x raptor + 750gb//Antec EA650//Lite-on DVDRW//Msi P7n D + X-Fi //Antec 900
''I dont suffer from insanity. I enjoy every minute of it.'
Aaron_8015 is offline   Reply With Quote
Old September 25th, 2009, 05:15 PM     #3 (permalink)
It's a Desktop.
Gateway, Model SX2800.
Processor: Intel Core 2 Quad CPU, Q8200 @2.33GHz 2.34GHz
Ram: 4GB
System Type: 64 bit Operating System.
Not sure how much of that information you need. Just trying to make sure I got it all. I think thats everything.
Thanks Again!
Old September 25th, 2009, 05:37 PM     #4 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
From the specs page http://www.gateway.com/systems/product/529668287.php it shows you have an available PCI-E x16 slot which means you can add on a better gpu. The problem is the case size and the power supply. It only has a 220w psu and you've got a small form factor case. Therefore its going to be tough to find a card that will work well with that setup.
Linus Torvalds
RicheemxX is offline   Reply With Quote
Old September 25th, 2009, 05:52 PM     #5 (permalink)
So lets say I went to Newegg or Amazon to see if I could look for anything that might fit my computer, what specs would I look for? Is there certain system info that would tell me if it would run with my Power supply and fit in my case? Something under around or under $150 would be great for me.
But it's good to know that I can atleast upgrade it. Makes me feel better about the system overall.
Old September 25th, 2009, 06:06 PM     #6 (permalink)
Purple People Eater
nickslick74's Avatar
This video card should fit (2nd review states your exact model).
Newegg.com - SAPPHIRE 100253HDMI Radeon HD 4650 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Low Profile Video Card - Desktop Graphics / Video Cards = $54.99
Not sure if your computer case supports a standard ATx power supply, but if it does this Antec would be nice.
Newegg.com - Antec Basiq BP430 430W Continuous Power ATX12V Version 2.2 Active PFC Power Supply - Power Supplies = $44.95
Cerca Trova - Seek and ye shall find
nickslick74 is offline   Reply With Quote
Old September 25th, 2009, 06:11 PM     #7 (permalink)
Aaron_8015's Avatar
This should work fine IF the PSU will fit in the case.
(after looking at the link from 'Rich' you would really have to make sure it will fit).
9800GT (low profile)
Newegg.com - SPARKLE SX98GT512D3L-NM GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video Card - Desktop Graphics / Video Cards
OCZ 400W unit.
Newegg.com - OCZ StealthXStream OCZ400SXS 400W ATX12V Active PFC Power Supply - Power Supplies
Old September 25th, 2009, 06:29 PM     #8 (permalink)
I think I'll go with the Radeon HD 4650 Card. I'm not really sure if the Power Supply's would fit, as I'm not even sure how to check, so better safe than sorry. Thanks so much for the help guys, you really made my day!
Very basic Javascript question flutter Webmastering and Programming 5 February 27th, 2009 11:36 AM
Basic OS question anken Applications and Operating Systems 9 February 20th, 2004 04:48 PM
Very Basic Question Logic Linux and Unix 3 September 15th, 2003 05:59 PM
a really basic question... monroeski General Discussion and Buyer Guidance 2 September 5th, 2002 01:10 AM
basic question Dragontech Webmastering and Programming 7 April 20th, 2002 09:57 PM
Is It Just Me? (2870)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
