Antec 900 Fan Controller help
Currently Active Users: 1284
Discussions: 200,929, Posts: 2,379,145, Members: 246,296
Old October 3rd, 2009, 10:18 PM   Digg it!   #1 (permalink)
I was wondering what the best fan controller would be for the Antec 900 case that would fit into a 5.25" bay. I have the stock fans and a Zalman 9500 Heatsink. The stock fans each have there own speed control, but i want to set it up so i can use one controller to control all the fans. Do i need to get adapters for all the fans?
Specs:
Antec 900 case
Corsair 520w modular power supply
AMD Athlon 5000+ Black Cpu
Gigabyte GA-m61p-s3 Motherboard
snbase is offline   Reply With Quote
Old October 3rd, 2009, 10:22 PM     #2 (permalink)
Aaron_8015's Avatar
Send a message via MSN to Aaron_8015 Send a message via Skype™ to Aaron_8015
Read down......
Q6600//6gb//2x 260GTX//2x raptor + 750gb//Antec EA650//Lite-on DVDRW//Msi P7n D + X-Fi //Antec 900
''I dont suffer from insanity. I enjoy every minute of it.'
Aaron_8015 is offline   Reply With Quote
Old October 3rd, 2009, 10:54 PM     #3 (permalink)
I want to get the Scythe Kaze Master 5.25" Fan controller KM01-BK. What kind of adapter would i need or does this controller come with the proper adapters?
Old October 3rd, 2009, 10:56 PM     #4 (permalink)
Aaron_8015's Avatar
AFAIK you cannot use a fan controller to control the stock fans.... no mater what adapters you buy.....
Mabye you can read this....
Google Image Result for http://www.dvhardware.net/reviews/vantec_nxp201/vantec_fan_controller_8.jpg
I imagine you need something like this...
Newegg.com - APEVIA Power 4 PIN Adapter TO 3 PIN Fan Adapter Model CVT43 - Cables
Ignore previous post I wasn't thinking properly (guess I should'nt post at 3am).
antec 900 cksboy15 PC Modification 2 August 30th, 2009 12:05 PM
Slugfest: Antec 900 Vs Coolermast 690 Fizur2002 IMO Community 0 September 25th, 2008 06:53 AM
antec 900 case problems mdog011 Technical Support 2 July 3rd, 2008 05:03 PM
Antec 900 Fan Problem Help lpbassics Technical Support 8 June 16th, 2008 11:28 PM
Antec 900 vs P180b? Ryan220587 General Tech Discussion 22 February 10th, 2007 01:59 PM
Is It Just Me? (2867)
Obama the Muslim (14)
Regular Build (2)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
