Help with gaming Build  | | |
October 16th, 2009, 11:56 PM
#41 (permalink)
| | PC Upgrade Procrastinator
| Quote:
Originally Posted by gangsta21 Wiat What can't you? Is it because I should choose my self? |
I think your missing the point here, we're not here to make your choices for you, or make up your mind for you, we offer suggestions, and advice, as well as try to explain why, with out going into much detail, its ultimately up to you to decide on your parts.
as others have said, you need to start doing some of this research and studying on your own.
as to what parts work with what, and what parts are good, for what reasons, etc, its all part of learning about your PC, whether your going to build it yourself or have someone else do it for you.
__________________ Quote:
October 17th, 2009, 12:00 AM
#42 (permalink)
| Quote:
as to what parts work with what, and what parts are good, for what reasons, etc, its all part of learning about your PC, whether your going to build it yourself or have someone else do it for you. | Yeah I get what your saying. Hmmm LOl now im trying to decide wheter to wait for cyber tuesday or get it now. Well I'm eager for a new computer. Guess I gotta research a little first. You see I'm a little skeptical right now, first time builder =P so I'm asking many questions etc |
October 17th, 2009, 01:08 AM
#43 (permalink)
Being skeptical is good, but you will ultimately choose what to buy. I could build you a kick butt gaming rig, but you would probably cry at the price tag. It will be between $3-4000. You have to compare suggested parts for yourself. You probably found us by google, take a part # ( 4870, gtx275, etc...) and google it. Read the reviews, some good,bad or ugly. You will see a pattern after a few reviews of a given part. We will make suggestions, but not choose for you. If you really want, I will make you a list for a moderate gaming computer, it won't be in your price range because it is made for MY preferences, from MY research, for MY needs, and in MY budget.
I have just built 2 new ones. I will list all the specs., they will cost you about $3000 though. To build one for you, there are companies out there; Dell,HP, Gateway, etc.... You won't get as good as one you do yourself, but it is easier.
Again, Aaron has picked out some good parts for you, do some research. I will try to list all the essential parts to build a rig.
Case-holds it all
Processor-CPU,chip, examples i7,i5,dual core pentium
Motherboard-mobo for short, what the processor and all is mounted on
RAM- memory
Harddrive-HDD, stores files,OS
Graphics Card-gpu, runs video, may be integrated on mobo
Power Supply-ps, takes AC power from the wall and powers the computer
CD/DVD drive- place to put cd's/dvd's also needed to load programs/OS
Operating System-OS, Windows,Linux, you get the picture here
Monitor- screen, you probably have one
Mouse/Keyboard- if you don't know quit now.
These are the essentials. I will come on tomorrow and update this with the parts I would get. This will be one of my actual computers.
__________________ Vi per Concordiam F@H Team 111 TEAM STATS |
October 17th, 2009, 10:58 AM
#44 (permalink)
| Quote:
Originally Posted by Flying JJ Being skeptical is good, but you will ultimately choose what to buy. I could build you a kick butt gaming rig, but you would probably cry at the price tag. It will be between $3-4000. You have to compare suggested parts for yourself. You probably found us by google, take a part # ( 4870, gtx275, etc...) and google it. Read the reviews, some good,bad or ugly. You will see a pattern after a few reviews of a given part. We will make suggestions, but not choose for you. If you really want, I will make you a list for a moderate gaming computer, it won't be in your price range because it is made for MY preferences, from MY research, for MY needs, and in MY budget.
Case-holds it all
RAM- memory
These are the essentials. I will come on tomorrow and update this with the parts I would get. This will be one of my actual computers. | LMFAO I won't cry. According to my prefences I thgouth need a rig that cost that much |
October 17th, 2009, 12:58 PM
#45 (permalink)
| Quote:
Originally Posted by gangsta21 Wiat What can't you? Is it because I should choose my self? | There's 2 main reasons why.
No. 1 is that there's no 'right' part to buy. It's all based on opinion. Some people would suggest a 5000 series Radeon, and others would suggest a 4000 series. When I was building my PC, there was an argument between 2 members over which power supply I should get (one recommended a PSU and the other said it would not work; turns out it did work fine).
No. 2 is building a computer is a kind of experience. It's much more satisfying putting together parts that you've chosen, rather than just buying it all because somebody told you to. It's also useful to be able to chose the right parts. Since building my first pc, I've designed lots of computers for people, and it helped when I upgraded it, because I knew exactly what its strengths and weaknesses are.
Live fast, die young, leave a big fat corpse
Antec900//Core2Duo E6750@3.6ghz//Gigabyte 965P-DS3//2x2GB Corsair XMS2//XFX HD4870 1GB//Zalman7800
October 17th, 2009, 01:57 PM
#46 (permalink)
| Quote:
No. 2 is building a computer is a kind of experience. It's much more satisfying putting together parts that you've chosen, rather than just buying it all because somebody told you to. It's also useful to be able to chose the right parts. Since building my first pc, I've designed lots of computers for people, and it helped when I upgraded it, because I knew exactly what its strengths and weaknesses are. | Yes But I've heard that some parts don't work well together. |
October 17th, 2009, 05:21 PM
#47 (permalink)
| Quote:
Originally Posted by gangsta21 Yes But I've heard that some parts don't work well together. | That's the kinda thing that we can help you with. I'm not saying we wont help you, just that you should do some research and make some decisions of your own |
October 17th, 2009, 07:56 PM
#48 (permalink)
| Quote:
Originally Posted by Rostock That's the kinda thing that we can help you with. I'm not saying we wont help you, just that you should do some research and make some decisions of your own | So like right now Can I list a bunch a parts and you guys tell me if they go well togerther? and then ill research it furhter |
October 17th, 2009, 08:28 PM
#49 (permalink)
October 18th, 2009, 10:35 PM
#50 (permalink)
