Are the two hard drives intentional? (also one of the dives is a 2.5" ideal for laptops) you would best pick up a 3.5".
Are you planning to overclock at all?
Q6600//6gb//2x 260GTX//2x raptor + 750gb//Antec EA650//Lite-on DVDRW//Msi P7n D + X-Fi //Antec 900 ''I dont suffer from insanity. I enjoy every minute of it.''
http://www.geeks.com/details.asp?inv...3LED-N&cat=CAS
Geeks has that case cheaper..
Just a heads up...
A. Acrylic cases are delicate...
there are several places they commonly crack.
B. They have poor airflow compared to most modern cases, unless your willing to chance modifying it.
C. unless you do an AMAZING job of wiring it tends to look a bit tacky...
I suggest spending some real time tidying up ALL wiring
11-Bay ATX Transparent Plastic Computer Case w/3 LED Fans
Just a heads up...
Well I would'nt leave something that you need out..... (that would be silly).
I gather you have a mouse also.... If you are planning on using that terabyte caviar green for your OS... I recomend you pick up this caviar black instead.
