Thread: Need help with cpu cooler
October 17th, 2009, 01:22 PM #1Junior Member
- Oct 2009
- Location
- Indiana
- 20
I purchased an aftermarket cpu cooler and it fits on my motherboard real nice and looks good inside my case. Then I went to plug it in and it has a 4 pin connector and my stock cpu cooler had a 3 pin. On the box for connector type it says 4 pin pwm mode or 3 pin thermistor mode. The 3 pin part of the connector plugs into my board but does not work. The cooler itself works if I plug it into the 3 pin plug for the chassis fan so I know the cooler is good. My stock fan has a red, black and blue wire going to the plug. The new cooler has a red, black, blue and yellow wire going to the plug and the 3 pin part uses the red, black, and yellow and leaves the blue going nowhere. Anway to make this work?
October 17th, 2009, 01:50 PM #2
Can you just use the chasis fan header?
Did the CPU cooler header work before you got this new cooler? If so, there is no reason why it shouldn't still be working.Q6600@4Ghz | i7 920@4.4Ghz |E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
October 17th, 2009, 04:10 PM #3Junior Member
- Oct 2009
- Location
- Indiana
- 20
The header still works when I plug the stock cooler back in. I might have to get some kind of adapter.
October 20th, 2009, 09:30 AM #4Junior Member
- Oct 2009
- Location
- Indiana
- 20
I decided to get another cooler, the other one was free after the rebate so I am not out anything. Anyways, the new heatsink and fan have a three wire plug like I need. But, another problem arises. The new fan has a red, black, and yellow wire, old fan had red, black and blue wires. The new fan works but my mobo doesn't recognize that there is a fan there.
October 20th, 2009, 09:31 AM #5
That shouldn't really make any difference. As long as the Heatsink is cooling properly, then that's all that really matters.
(also different manufactures use different color wire all the time, so that's nothing to worry about)Q6600@4Ghz | i7 920@4.4Ghz |E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
October 20th, 2009, 09:40 AM #6Junior Member
- Oct 2009
- Location
- Indiana
- 20
Thanks, its working, not sure about properly with the temps I am getting.
October 20th, 2009, 09:41 AM #7
What are your temps?
What's the specs of your system? (CPU, Motherboard, heatsink being the most prevalent)Q6600@4Ghz | i7 920@4.4Ghz |E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
October 20th, 2009, 10:02 AM #8Junior Member
- Oct 2009
- Location
- Indiana
- 20
I have a short story about it here on another thread.
Help with cooling
November 5th, 2009, 01:11 PM #9Junior Member
- Nov 2009
- 2
i had a problem with the temprature , and after a long working time i discovered that the temp showing on the bios was not true !!
the sensor was wrong calculating the temprature. the cpu was cold and the unit shwed above 90 celz !!
daniel
CPU cooler
By athlonxpguy in forum Processors, Memory, and OverclockingReplies: 11Last Post: February 19th, 2008, 07:52 PM -
Need new CPU cooler
By blubomber in forum Processors, Memory, and OverclockingReplies: 5Last Post: December 10th, 2007, 03:27 PM -
CPU Cooler Adapter
By EricInLouisville in forum General Tech DiscussionReplies: 0Last Post: September 12th, 2005, 08:38 PM -
Good cpu cooler
By bombledmonk in forum Processors, Memory, and OverclockingReplies: 7Last Post: August 19th, 2003, 09:32 PM -
What's your CPU Cooler?
By neodave in forum Processors, Memory, and OverclockingReplies: 28Last Post: April 18th, 2002, 11:03 PM
That's hilarious GZ! Nothing like a little controversy to get people stirred-up. This will be fun to watch :)
Xbox One Announced
