Results 1 to 4 of 4
    Dec 2009
    2
    Having New Computer [power?] Problems
    So, I just finished my new PC build, and when I try to turn it on, the fans and whatnot run for a second, then it all cuts out. There's still a light in the case that's on, though. I have to turn the PSU off and on again, then the power button on the case, for it to happen again, though. I'm guessing it's a power issue? I've tried disconnecting one of the cards and a few of the fans, still no go.
    This is the build: Wish List TigerDirect.com
    Except for the MoBo, which is actually: XFX MB-N790-IUL9 Desktop Board - MBN790IUL9 - Buy.com
    Nov 2006
    Portsmouth, UK
    4,159
    Sounds like a grounding problem.... take it all out of the case and assemble on a carboard box and try and get it to POST.
    Dec 2009
    2
    Fixed the problem, I just didn't have stand-offs between the MoBo and the MoBo tray. Thanks for the tip.
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    Quote Originally Posted by ShadyElvis View Post
    That would be a BIG grounding problem.
    Hard Sayin Not Knowin
  1. Computer Problems - High CPU Usage - Computer Lag
    By aspinn in forum Technical Support
    Last Post: April 29th, 2009, 01:44 AM
  2. computer problems
    By kayla_slocum2001 in forum Technical Support
    Last Post: October 24th, 2008, 07:12 AM
  3. computer problems
    By helplz in forum General Tech Discussion
    Last Post: December 21st, 2007, 06:36 PM
  4. Serious Computer problems, please help!
    By PrometheusFG in forum Technical Support
    Last Post: July 25th, 2007, 11:37 AM
  5. many computer problems
    By bharford in forum Technical Support
    Last Post: December 16th, 2003, 09:25 AM
