Results 1 to 1 of 1
    Nov 2009
    39
    Another Gmaing Build Compatibility Check
    Compatibility check on this
    LG 22X DVD Burner - Bulk Black SATA Model GH22LS50 LightScribe Support - OEM Item #: N82E16827136168Return Policy: Standard Return Policy
    Protect Your Investment (expand for options27-136-168|hide options27-136-168)
    Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info27-136-168.0.18)
    • 1 year: $6.99
    • 2 year: $11.99
    $28.99 select item 2 quantity of item 2
    Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm ... - Retail Item #: N82E16811147153Return Policy: Standard Return Policy
    $49.99 select item 3 quantity of item 3
    Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive Item #: N82E16822136073Return Policy: Standard Return Policy
    $55.99 select item 4 quantity of item 4
    Acer X203H bd Black 20" 16:9 5ms Widescreen LCD Monitor - Retail Item #: N82E16824009158Return Policy: Monitor Replacement Only Return Policy -$25.00 Instant
    $149.99$124.99 select item 5 quantity of item 5
    GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - Retail Item #: N82E16813128392Return Policy: Standard Return Policy $10.00 Mail-in Rebate Card13-128-392 $84.99 select item 6 quantity of item 6
    XFX HD-575X-ZNFC Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail Item #: N82E16814150448Return Policy: VGA Standard Return Policy -$5.00 Instant
    $144.99$139.99 select item 7 quantity of item 7
    OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ... - Retail Item #: N82E16817341016Return Policy: Standard Return Policy -$25.00 Instant
    $25.00 Mail-in Rebate Card17-341-016 $89.99$64.99 select item 8 quantity of item 8
    G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail Item #: N82E16820231277Return Policy: Memory Standard Return Policy
    $104.99 select item 9 quantity of item 9
    AMD Athlon II X2 250 Regor 3.0GHz Socket AM3 65W Dual-Core Processor Model ADX250OCGQBOX - Retail Item #: N82E16819103681Return Policy: CPU Replacement Only Return Policy
    Suggetions are great =D
  1. Replies: 16
    Last Post: December 19th, 2009, 07:34 AM
  2. New build, compatibility
    By babicz in forum PC Modification
    Last Post: December 9th, 2009, 08:03 PM
  3. Compatibility Check for first time builder
    By tomblits in forum General Tech Discussion
    Last Post: August 1st, 2009, 03:00 AM
  4. Compatibility Check
    By Irregular Joe in forum General Tech Discussion
    Last Post: May 21st, 2008, 08:23 PM
