Results 1 to 4 of 4
Thread: case
    Oct 2008
    105
    case
    CM 690 II Advanced with window? or the lian li p50wb
    why is the cm so cheap? whats the case made from plastic steel aluminum
    Jan 2003
    Outside the box
    8,489
    4
    Dang you lazy or something read the specs CM 690 II Advanced - Cooler Master
    cheap is a relative term, I don't consider a $100 case as being cheap!!
    Healdsburg, CA
    13,302
    The CM 690 II Advanced is constructed of steel with a plastic bezel. It's a very good case that offers excellent cooling and plenty of space to work in.
    The Lian Li is also a great design with many nice features such as tool less motherboard mounting. Many people swear by them, but they are expensive.
    Oct 2008
    105
    what case would yous recommend I looked up the difference between cooling with steel and aluminum and theres no difference and I like the look of the CM more the lian li
    down the bottom of the CM case I'm not sure if 2 140s or 2 120mm fans fit there?
  1. Recommend A Case or Site that sells Case
    By njolakoski in forum General Tech Discussion
    Last Post: March 28th, 2005, 06:44 AM
  2. Hand made Custom Case Vs Factory Case
    By Rubacant in forum PC Modification
    Last Post: November 8th, 2004, 02:58 AM
  3. antec sonata case come with a case fan?
    By ajna_star in forum General Tech Discussion
    Last Post: July 23rd, 2004, 08:41 AM
  4. best case cooling scenario - open vs. closed case
    By rh71 in forum General Tech Discussion
    Last Post: June 19th, 2004, 10:50 PM
  5. Case Rear Panel only, Case search, wood mod
    By LaidBackLux in forum PC Modification
    Last Post: May 18th, 2003, 03:06 PM
