Results 1 to 15 of 15
    Oct 2008
    105
    High end build help
    I would like to see what you guys could come up with 3500 AUD build I need pretty much everything besides a mouse... I don't want to have watercooling. and It would be good if you can make a GAMING computer from here
    PC Case Gear
    Thanks.
    Minnesota
    17,432
    Gigabyte GA-P55A-UD4 Motherboard [GA-P55A-UD4] - $199.00 : PC Case Gear
    G.Skill F3-12800CL9D-4GBNQ (2x2GB) DDR3 [GS-F3-12800CL9D-4GBNQ] - $143.00 : PC Case Gear
    Intel Core i7 860 [BX80605I7860] - $359.00 : PC Case Gear
    Sapphire ATI Radeon HD5970 2GB [11S-HD5970-2GBA] - $899.00 : PC Case Gear
    CoolerMaster HAF 932 Case [RC-932-KKN1] - $199.00 : PC Case Gear
    Prolimatech Megahalems Rev. B [MEGAHALEMS] - $68.00 : PC Case Gear
    Western Digital Caviar Black 500GB WD5001AALS [WD5001AALS] - $69.00 : PC Case Gear x3 (RAID 0 + Backup, or RAID 5)
    ASUS Xonar Essence STX [XONAR-ESSENCESTX] - $209.00 : PC Case Gear
    BenQ G2420HD 24 Inch Widescreen LCD Monitor [G2420HD] - $229.00 : PC Case Gear
    Logitech G19 Gaming Keyboard [920-000984] - $179.00 : PC Case Gear
    Samsung SH-B083A Blu-ray DVD Combo Drive [SH-B083A] - $134.00 : PC Case Gear
    BenQ DW240S 24x Internal DVD±RW Drive Retail Box [DW240S] - $35.00 : PC Case Gear
    ROCCAT Kave Real 5.1 Surround Sound Gaming Headset [ROC-14-500] - $139.00 : PC Case Gear
    Microsoft Windows 7 Home Premium 64bit OEM [GFC-00599(W7HP64-1)] - $135.00 : PC Case Gear
    Enermax Revolution85+ SLI 850W [EN-ERV850EWT] - $289.00 : PC Case Gear
    Sub-Total: $3423.00
    Missing Fans for CPU cooler, and some quality Thermal paste, with so many options of the latter on that site, figured leave it up to you. MX-3, Shin Etsu, OCZ Freeze, etc.
    Wasn't sure on speakers, and what you had, but that sound card is supposed to be really good with Headsets, and the headset I linked, I had read is a pretty good rock solid 5.1 Gaming set. Just wish they sold that brand over in the states, or at least easily find it around, I think Performance PC's is one of the few US sites that sells them.
    Jan 2003
    Milwaukee, WI
    7,657
    I'm surprised you'd suggest spending so much on audio...
    Why?
    the Antec 600 is almost "HAF" the price
    or the 300 if windows dont matter
    Blue Ray? dont need that for gaming...
    I'm assuming your just maxing the budget?
    Minnesota
    17,432
    Couple with the Headset (Supposed to be a really good 5.1 Gaming headset) with the sound card... the sound card has amplifier for headsets.
    BIG Case, plenty of room for upgrades, additions later. also the fact there is a Radeon 5970 in that list, plenty of room, along with the size of the CPU cooler, not sure how wide the Antec cases are, but you'll need to have a very wide case for that cooler.
    was originally going to go with the HAF 922, but then saw the 932, figured couldn't hurt with a bit more room. with 230mm intake fans, case should be wide enough too.
    case is completely up to end user, and the list is just an example, obviously things can be added/deleted, etc.
    The Bluray drive is a combo BD/DVD drive, so its dual purpose, figured incase they wanted to watch a BD movie or something on it, with the 24" display.
    if I were spending the money, this is an example of what I would get for a gaming rig, (well I'd be looking at a Socket 1366 platform and Quad core), I'm also Partial to Coolermasters cases as well, nothing against Antec, their good too. its usually a toss up between CM, Antec and Thermaltake when it comes to cases for me.
    Why confine all that hardware in an Antec 300 case, its a smallish midsize case, that 5970 is a LOOOOONG card, coupled with that CPU cooler, 3 hard drives, 2 Optical drives, and whatever else, its going to be a tight fit, if the GPU will even fit in it.
    Jan 2003
    Milwaukee, WI
    7,657
    True... and you still didnt spend all his money...lol
    He did ask what we'd buy with that budget...
    Oct 2008
    105
    Jan 2003
    Milwaukee, WI
    7,657
    I wouldnt be looking at anything from AMD with a budget like that...
    SLI is a poor choice as well
    The 5970 is head and shoulders above that paired 5850!
    Does that SSD support trim?
    what controller does it use?
    Oct 2008
    105
    Controller: Indilinx Barefoot Eco IDX110M01-LC pretty sure it has trim from what i read
    why not look at AMD 6 core? its cheaper then i7 930 and on a post i did before most people were leaning towards the 6 core but i agree with the graphic card but i dunno what would you recommend ? what case should i go for
    Minnesota
    17,432
    Quote Originally Posted by JPMiller View Post
    Quote Originally Posted by Yoda11 View Post
    Corsair Nova V128 SSD review
    Yep, it has Trim.
    Ultimate Member Imperion1's Avatar
    Center of the U.S.
    2,031
    6 core is way overkill. A little over a year ago is when a very very few games started using multicore cpus, otherwise most games still use only 1 core.
    And with a budget like yours, I would get an Intel I7. And all my computer builds are AMD.
    I've noticed that Intel built systems boot quicker and load games and programs quicker.
    If you want a quicker running system, Shyguy did give you a really good build list.
    I'd add this for cooling.
    Corsair Hydro Series H50 CPU Cooler [CWCH50-1] - $129.00 : PC Case Gear
    Its Corsair's H50 cpu water cooler. It works really good on my AMD 550 X2. Idle temp on mine is 29c. At max cpu, its 40c. Your case would have to be able to mount a 120mm fan for this to work.
    Apr 2010
    29
    Thanks for sharing...
    Minnesota
    17,432
    ... bot?
    Jan 2003
    Milwaukee, WI
    7,657
    http://www.techimo.com/forum/search....archid=2675788
    I'm not sure if hes a total jag, or just weird...
    some posts seem ok/legit... then others are just random cut and paste or just "random" period
    Apr 2010
    Australia
    19
    with that budget go get an i7 980x, they are sooooooooo worth the premium
    and an xfx card for graphics maybe
    and GB ud9 mobo i know it might be pushing a budget but im an aussie to and compare to some otger places it,s gold!!!
  15. #15
    Minnesota
    17,432
    um, why a 980x?
    if this is a gaming rig, the 2 extra cores right now are a total waste, and I don't see how its "sooooooooo worth the premium"
    do you have any idea how much those cost, buy one and you have sooooooo much less left over for the rest of the build. @ 1500 AUD... forget it, with a budget of 3500 there's no way he'd have enough left over for the rest of the system, he'd have a partially barely function PC in the end.
    if budget was unlimited, sure, grab a 980x, and a more premium price XFX, as well as a more expensive Gigabyte Mobo... but seriously, there is a budget to adhere to.
    i7 980x = $1500
    Gigabyte UD9 mobo = $650 (pre-order)
    XFX 5970 GPU = $850
    thats $3000 of the $3500 budget...
    lets see what else is needed...
    RAM
    HDD
    Optical Drive
    Case
    PSU
    OS
    Headset
    Keyboard
    LCD Display
    And this is a bare minimum configuration as far as components go.
    if they wanted some more options like Dual Optical Drives, multiple hard drives, Aftermarket CPU cooler for Overclocking, Sound card for better audio with headset, etc
    so yeah, with the parts your suggesting, this members desired build will be impossible to meet with their budget they posted.
  1. First Build - Mid/High End Gaming Computer
    By thats_no_moon in forum PC Modification
    Last Post: November 27th, 2009, 04:24 PM
  2. New high end gaming build. Please help!
    By bernardstachman in forum PC Modification
    Last Post: October 14th, 2009, 04:02 PM
  3. F.E.A.R. Specs, Need HIGH-END PC
    By Top Gun in forum General Gaming Discussion
    Last Post: January 21st, 2009, 07:08 PM
  4. High end system needs a high end video card
    By bandin in forum Graphics Cards and Displays
    Last Post: July 16th, 2004, 02:12 AM
