Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 66
    May 2010
    56
    Need Help with Dell Dimension4600
    Hi all am new.
    I need help upgrading my graphics card on my dell dimension 4600. I dont know crap when it comes do hardware.
    I recently purchased a ATI Radeon 9200 256 MB AGP 3D Video Card TV-Out VGA DVI
    Link --- ATI Radeon 9200 256 MB AGP 3D Video Card TV-Out VGA DVI - eBay (item 290372678566 end time May-20-10 08:02:21 PDT)
    I tryd everything to get that to work
    My old card that is crapping out on me is a ATi Radeon Pro 128MB Radeon 9800 DVI VGA AGP Video Card.
    Link ATi Radeon Pro 128MB Radeon 9800 DVI VGA AGP Video Card - eBay (item 270571647498 end time May-29-10 13:20:55 PDT)
    I just want something that can support two monitors and is somewhat decent. I dont game or do much more then watch hd movies on youtube.
    Any help would be great.
    Thank you!
    South Jersey
    11,368
    Hi Dunlop,
    Welcome to TechIMO.
    What happened when you tried installing the Radeon 9200? Hard to provide much help if we can't figure out what's wrong.
    May 2010
    56
    Just has black screen after hardware is installed. Drivers are installed. It doesnt even sound like it even boots up all the way, after the new card is in. I can see the fan spinning so i know it has power.
    My old card i would have to plug the power cord into it. This new one doesnt even have an option to plug power into ???????
    arg
    MY computer specs
    CPU
    Intel Pentium 4
    Cores 1
    Threads 1
    Name Intel Pentium 4
    Code Name Northwood
    Package Socket 478 mPGA
    Technology 0.13um
    Specification Intel(R) Pentium(R) 4 CPU 2.80GHz
    Family F
    Extended family F
    Model 2
    Extended model 2
    Stepping 9
    Revision D1
    Instructions MMX, SSE, SSE2
    Bus speed 133.0 MHz
    Rated Bus speed 532.0 MHz
    Stock core speed 2800 MHz
    Stock bus speed 133 MHz
    Caches
    L1 data cache size 8 KBytes
    L1 trace cache 12 Kuops
    L2 unified cache size 512 KBytes
    Core 0
    Core speed 2793.0 MHz
    Multiplier x 21.0
    Bus speed 133.0 MHz
    Thread 1
    APIC ID 0
    Motherboard
    Manufacturer Dell Computer Corp.
    Model 0N2828
    Chipset vendor Intel
    Chipset model i865P/PE/G/i848P
    Chipset revision A2
    Southbridge vendor Intel
    Southbridge model 82801EB (ICH5)
    Southbridge revision 02
    BIOS
    Brand Dell Computer Corporation
    Version A07
    Date 11/06/2003
    Graphics
    Monitor
    Name DELL 1901FP on RADEON 9800 PRO
    Current Resolution 1280x1024 pixels
    Work Resolution 1280x1024 pixels
    State enabled, primary, output devices support
    Monitor Width 1280
    Monitor Height 1024
    Monitor Bpp 32 bits per pixel
    Monitor Frequency 75 Hz
    Device \\.\DISPLAY1\Monitor0
    RADEON 9800 PRO
    GPU R350
    Device ID 1002-4E48
    Subvendor ATI (1002)
    Technology 150 nm
    Transistors 117 M
    Release Date 2003
    DirectX Support 9.0
    DirectX Shader Model 2.0
    OpenGL Support 2.0
    Bios Core Clock 378.00
    Bios Mem Clock 338.00
    Driver ati2mtag.sys (6.14.10.6525)
    BIOS Version 113-A07517-100
    ROPs 8
    Shaders Vertex 8/Pixel 8
    Memory Type DDR
    Memory 128 MB
    Bus Width 256 Bit
    RAM
    Memory
    Type DDR
    Size 1024 MBytes
    Channels # Dual
    DRAM frequency 166.2 MHz
    CAS# Latency (CL) 2.5 clocks
    RAS# to CAS# delay (tRCD) 3 clocks
    RAS# precharge (tRP) 3 clocks
    Cycle time (tRAS) 7 clocks
    Windows XP
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    It doesn't surprise me the 9200 has no power plug, it is half the card as the 9800, it doesn't need one.
    At this point, I would be asking, did the first card really go bad, and is the second card really good?
    Do you have another AGP computer you can test them in?
    When I didn't have extra parts, the local computer shop would test things like video cards, for me.
    Hard Sayin Not Knowin
    May 2010
    56
    I have vertical lines around my mouse, and lines threw about just everything else on the screen. I reinstalled my old card drivers with no avail. I even updated them and still lines everywhere. Its just crazy at start up.
    Well since you said the 9200 is half the card, what do you recommend?
    I was looking at this one.
    ATI Radeon 9800 PRO 128MB AGP 8X 109A07500 Graphic Card - eBay (item 160430840506 end time May-13-10 13:02:07 PDT)
    Also whats a good psu. My fan on mine keeps freaking out and buzzing sometimes.
    If you suggest another card that requires me upgrading my psu thats fine. I have to stick something to stop the fan, sometimes so it doesnt freak.
    Thanks all
    Dec 2002
    New Hampshire
    8,059
    It looks like the same card, if they were both 9800PROs.
    The first one was worded funny, so I wasn't sure if it was a pro,
    You could probably go a little better, before that CPU would bottleneck.
    I have a HD3850 on a similar AMD system (3000)and it is bottlenecked by the CPU.
    If you don't game, a 9800pro is a top card for that system
    PassMark Software - Video Card Benchmark Charts
    I like Corsair to be safe.
    The 400Watt will handle that 9800PRO, If you were to go for a more demanding card like the HD3850 the 450watt will handle that easily.
    Newegg.com - Computer Hardware,Computer Cases,Power Supplies,Corsair Memory
    Dec 2002
    New Hampshire
    8,059
    If you want to shop around E-Bay go by this good list to be safe, on brand.
    Power Supply Info
    May 2010
    56
    I will prob just go with the pro... will let you know how it goes
    I always had my eye on this card though... AGP New Nvidia Geforce 7800GS 512MB DDR3 7800 GS AGP - eBay (item 270447764941 end time May-23-10 04:46:34 PDT)
    MMmmmmm I like anime
    Thanks guys
    Dec 2002
    New Hampshire
    8,059
    The 7800 GS should be better than the 9800 Pro, and should still not bottleneck that system
    It is a good idea to use a driver cleaner when going from ATI to Nvidia.
    driver cleaner - Google Search
    May 2010
    56
    Well just ordered a new ATI Radeon 9800 Pro, for $31.90
    Just sold the 9200 for 20bucks
    Took that money and bought one more gig of ram, now im maxed out at 2 gigs. Chose Elpida, cost me 27.88.
    There is a guy that has a 400w Sealthxstream for 40 dollars, is it worth it?
    Also how do i set up my avatar on here???
    May 2010
    56
    [quote=stroyal
    Can't remember about the avatar, seems to me you have to find a sight that hosts avatars, and link to that.[/quote]
    Where do you link though?
    You have been a great help stroyal, Thank you!!!
    Dec 2002
    New Hampshire
    8,059
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    According to Dell's website forum. One thing to look out for is not to buy a video card for the 4600 with more than 256MB of RAM.
  15. #15
    May 2010
    56
    Quote Originally Posted by Taxmancometh View Post
    Thanks for the heads up.... The card i ordered has 128MB. What would you recommend for a good 256mb AGP card?
  16. #16
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    Well, back in '05 I stuck in a 6600GT. It performed well. I played F.E.A.R in low-med quality and COD4 on it pretty well. But... you can find a 7600GT or 7600GS with 256MB which is far more superior. The GT would be better. Make sure it's AGP. Good luck!
    eXtreme Power Supply Calculator
  17. #17
    May 2010
    56
    k... i just got the new/used graphics card installed, still am having issues.
    I still have some horizontal lines, however if i restart my computer it will sometimes start with no problems at all. At start up it doesnt have any weird lines like it did before.
    I did reinstall the drivers for the card, and made sure it was for the 'pro' version!!!
    I dont know what to do again.
    This is a pic of what my old start up looked like. Everything is perfect now!!
  18. #18
    Dec 2002
    New Hampshire
    8,059
    What are the specs, on the power supply you are using
    Brand?
    12Volt rail amps, all of them, if more than 1 rail.
  19. #19
    May 2010
    56
    Brand?
    I do not know. I want to say 240w, from dell. Everything is pretty much stock, i did also just upgrade my ram to 2gigs. My old card was one of the first gens.. it was still the 9800 pro as well.
    I dont care if i have to go in and tell you off the label on my psu, but if there is another way, just tell me how and i will get back to you.
    Can speccy tell you?????
  20. #20
    Dec 2002
    New Hampshire
    8,059
    Quote Originally Posted by Dunlop View Post
    Sometimes specs can give us a hint.
    My 9700Pro ran on a 400watt Allies with 17 amps on the 12Volt, and it ran the power supply hot, because it was a cheap power supply and/or it was overloaded.
    Dell generally has very good power supplies, but are just big enough for the system they come in, so they are always small.
    Did the computer originally come with a 9800Pro??
  1. Dell support centre dsc.exe messing up dell inspiron 1300
    By dmdougie in forum Technical Support
    Last Post: November 18th, 2009, 08:30 AM
  2. Dell 2408wfp Monitor (new) and Dell 4600 (old) compatability?
    By angoos in forum Graphics Cards and Displays
    Last Post: July 5th, 2008, 05:59 AM
  3. new dell laptop... how do I turn off the dell alert system??
    By zskillz in forum Technical Support
    Last Post: April 25th, 2008, 04:52 PM
  4. What Dell motherboard will fit which Dell Case?
    By crazyray in forum General Tech Discussion
    Last Post: February 8th, 2006, 05:02 PM
  5. IBM R-series vs. Dell 600M vs Dell D600
    By zskillz in forum General Tech Discussion
    Last Post: July 20th, 2004, 08:49 PM
