Thread: Help build first gaming pc
June 11th, 2010, 01:26 PM #1Junior Member
- Jun 2010
- 1
Im trying to spend under 1000 dollars and was wondering if this would work for gaming pc.
Processor: intel Core i5-650 Clarkdale 3.2GHz 4MB L3 Cache LGA 1156 73W Dual- core
Motherboard: GIGABYTE GA-H57M-USB3 LGA 1156 Intel H57 HDMI USB 3.0 Micro ATX Intel
Memory: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Hard Drive: HITACHI Deskstar HD31000 IDK/7K (0S00163) 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
Video Card: XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0
x16 HDCP Ready CrossFireX Support Video Card
Computer case: Ultra ULT40278 XT MicroATX Tower Computer Case - MicroATX
Power supply: Ultra LSP750 750-Watt Power Supply - ATX, SATA-Ready, SLI-Ready, 135mm Fan,
Dvd Burner: LG Black 24X DVD+R 8X DVD+RW 16X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM SATA DVD Burner
Here are the links in order.
Newegg.com - Intel Core i5-650 Clarkdale 3.2GHz 4MB L3 Cache LGA 1156 73W Dual-Core Desktop Processor
Newegg.com - GIGABYTE GA-H57M-USB3 LGA 1156 Intel H57 HDMI USB 3.0 Micro ATX Intel Motherboard
Newegg.com - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Newegg.com - HITACHI Deskstar HD31000 IDK/7K (0S00163) 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Newegg.com - XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Ultra ULT40278 XT MicroATX Tower Computer Case - MicroATX, USB, 90mm Fan, 120mm Fan, All-In-One Card Reader, Black at TigerDirect.com
Ultra LSP750 750-Watt Power Supply - ATX, SATA-Ready, SLI-Ready, 135mm Fan, Lifetime Warranty at TigerDirect.com
Newegg.com - LG Black 24X DVD+R 8X DVD+RW 16X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM SATA DVD Burner - Bulk - CD / DVD Burners
June 11th, 2010, 01:53 PM #2
Hi and welcome to TechIMO.
Any reason you have gone for the i5 with the on-board GPU?
I would look into the i5 750 and P55 motherboard as you would really have no need for the on-board on a gaming PC (unless for troubleshooting purposes.....
I would pick a different power supply... Ultra does not have the best reputation also a 750w unit is way overkill... even if you get another 5770....
Newegg.com - OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
This OCZ PSU has 20% with promo code also has 20 MIR and free shipping....
Will happily run your system even with a second 5770, not to mention its good quality .
June 11th, 2010, 08:17 PM #3
Case and PSU are poor choices...
Ultra are garbage and that case leaves little room for clean wiring or high-end cards or airflow...
Heres much better choices for less money...
Newegg.com - Antec TWO HUNDRED S Black ATX Mid Tower Computer Case
Newegg.com - XCLIO Godspeed 747 Fully Black Finish 0.5 mm SECC / ABS Plastic ATX Mid Tower Computer Case
Newegg.com - Thermaltake V3 Black Edition VL80001W2Z Black SECC / Plastic ATX Mid Tower Computer Case
Newegg.com - Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case
Newegg.com - Antec VSK-2000 Black ATX Mid Tower Computer Case
Newegg.com - SILVERSTONE ST50F-ES 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
Newegg.com - OCZ StealthXStream OCZ500SXS 500W ATX12V / EPS12V Active PFC Power Supply
Newegg.com - XION XON-630P12N 630W ATX12V SLI Ready CrossFire Ready Power Supply
Newegg.com - Thermaltake TR2 W0388RU 600W ATX 12V v2.2 Power Supply
Newegg.com - OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
Newegg.com - XCLIO STABLEPOWER 500W 500W ATX Active PFC Power Supply
Save $10 on the HD...
Newegg.com - Western Digital Caviar Blue WD10EALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Same specs/warranty
I wouldn't buy LG even if it wasn't more expensive...
Newegg.com - Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - CD / DVD Burners
Save $5 and save the hassle of taking a 50/50 chance on getting a loud optical drive besides
Save $20 and get a bigger ATX board with better heatsinks...
Newegg.com - GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel MotherboardLast edited by JPMiller; June 11th, 2010 at 09:35 PM.
i7 Gaming Build
By kramo123 in forum General Tech DiscussionReplies: 29Last Post: January 19th, 2010, 11:57 AM -
Gaming Build Help!
By james.c in forum PC ModificationReplies: 28Last Post: September 2nd, 2009, 09:45 PM -
first build for gaming
By Mcee in forum General Tech DiscussionReplies: 10Last Post: October 26th, 2008, 01:39 PM -
help build gaming pc
By Ryan5285 in forum PC ModificationReplies: 11Last Post: August 18th, 2008, 04:36 PM -
what you think about this gaming system i'm gonna build? (Cheap gaming)
By CJL17 in forum General Tech DiscussionReplies: 5Last Post: May 23rd, 2005, 02:25 PM
Fully action and Little comdey movie with lot of fun. You are also watch it's previous part Iron Man & Iron Man 2 they are fantastic. Now watch Iron Man 3 which are super fantastic as compare with...
! Full HD !! Watch Iron Man 3...
