August 24th, 2010, 10:39 AM #1Member
- Jul 2005
- 141
From Celeron 600MHz to Pentium III 933MHz on a Compaq 0688h Mobo - Possible?
Hi guys,
I know the max. memory supported is just 512MB, but how about max. CPU speed?
Thanks!
August 24th, 2010, 12:23 PM #2
First off will see a marginal gain, we are talking slow to not quite as slow.
If a cpu fits the socket it usually works, as long as the bios is supporting the cpu.
In your case it seems that was an option.
Processor Intel Pentium 3 EB, Coppermine 2, Socket 370FC-PGA, Mainboard Compaq 0688hLast edited by quickoldcar; August 24th, 2010 at 12:25 PM.
DynaIndex.com - Dynamic search index of websites, links, feeds, title, description, keywords and thumbnail snapshot.
August 24th, 2010, 01:17 PM #3Member
- Jul 2005
- 141
Thanks for your response quickoldcar.
"you will need to know what is the maximum FSB clock rate your motherboard supports"
- How to Upgrade Your CPU | Hardware Secrets
CPU-Z gives this info "Multiplier x FSB: 9.0 x 66.5 MHz" under "Processor Information", and "FSB speed: 66.0 MHz" under "DMI Processor". So according to the URL above, then I could only upgrade to max. Celeron 766MHz???
August 24th, 2010, 01:19 PM #4Member
- Jul 2005
- 141
Well...
DMI Processor
manufacturer Intel
model Intel(R) Celeron(tm) processor 600E MHz
clock speed 600.0 MHz
FSB speed 66.0 MHz
multiplier 9.0x
1000 mhz Pentium III or 2.4Ghz Celeron
By velascony in forum Mobile ComputingReplies: 7Last Post: October 28th, 2003, 01:12 PM -
how do i OC pentium III 700mhz?
By twiztidtruckie in forum Processors, Memory, and OverclockingReplies: 8Last Post: September 8th, 2003, 09:59 PM -
Pentium II to Pentium III upgrade?
By Tagstar in forum General Tech DiscussionReplies: 8Last Post: January 16th, 2003, 12:24 AM -
Best Motherboard for Celeron/P-III
By kenl in forum MotherboardsReplies: 2Last Post: January 16th, 2002, 10:40 PM
What is your weekend plan.If you take a look of these you forget everything else. The Vampire Diaries Season 4 Episode 23 Greys Anatomy Season 9 Episode 24 Watch Broken City Online Watch Bullet...
Enjoy The Vampire Diaries Season 4...
