January 3rd, 2011, 11:54 PM #1Member
- Jan 2011
- Location
- Toronto, Ontario
- 30
Can any suggest air flow design for the NZXT Gamma chassis?
Hello, I just built my first pc last week and I've decided I want to improve the temperature of my system, which is why I'm asking for anyone to help me decide how to set up fans in my case. I need to know what sizes I should put, the CFM's, and where to mount them. I'll buy any amount of fans if needed, I just want to maximize the amount of cooling I can get from just fans.
There's a max amount of 2 at the top, 2 at the back (including PSU exhaust), 1 in the bottom (PSU fan intake), 1 at the lower front face, and 2 on the side panel.
I will appreciate any help, and look forward to any recommendations!!!
NZXT :: Unique. Unprecendented. Inspired - Gamma Product Detail
MODEL GAMMA SERIES CASE TYPE MID TOWER Black interior chassis FRONT PANEL MATERIAL Steel DIMENSIONS (W x H x D) 190 X 449 X 508 mm COOLING SYSTEM FRONT, 1 x 120mm
SIDE, 2 x 120mm
TOP, 2 x 140/120mm
REAR, 1 x 120mm, 23db/42CFM (included)
DRIVE BAYS 11 DRIVE BAYS
4 EXTERNAL 5.25" DRIVE BAYS
7 INTERNAL 3.5" DRIVE BAYS MATERIAL(S) Steel Construction EXPANSION SLOTS 7 WEIGHT 6 kg MOTHERBOARD SUPPORT ATX, MICRO-ATX, BABY AT CPU COOLER CLEARANCE 143.5mm (with fan)
168.5mm (without fan)
January 4th, 2011, 12:38 AM #2
Normaly front/side is intake and top/rear is exhaust... Pick up a few 120mm fans (specs wise is up to you, getting a high CFM fan is good, so long as you can put up with the noise).
Oh and welcome to TechIMO.I7 920 @ 4.2Ghz/6GB//GTX480 SLI/M4 64 GB + 1.5 TB + 2x 640 GB/Corsair TX950/ASUS blu-ray/ASUS P6X58D-E + X-Fi /LC PCK62
January 4th, 2011, 01:41 AM #3
+1 on Aaron's suggestions.
I usually setup things that exact same way. Its ok to do a little trial and error run on things though and check your temps with several different configurations.
January 4th, 2011, 02:13 AM #4Member
- Jan 2011
- Location
- Toronto, Ontario
- 30
alright I'll try it out then, probably going to mount one at the front, and one on the top. will that get me a negative pressure system or positive? im kind of confused about all this air flow dynamics!
January 4th, 2011, 02:49 AM #5
Dpends on the fans really.... Though as you will have two exhaust and one intake it will probably be negative.
Project NZXT Lexa > NZXT Lexus
By DarkStar02 in forum General Tech DiscussionReplies: 0Last Post: July 17th, 2006, 01:21 AM -
Its all about Air flow...
By AndreL in forum PC ModificationReplies: 11Last Post: March 23rd, 2006, 09:06 PM -
reversing air flow..
By vikeor in forum PC ModificationReplies: 17Last Post: February 25th, 2005, 08:06 PM -
How do i get Proper Air Flow within my case
By buddhafest in forum General Tech DiscussionReplies: 5Last Post: January 21st, 2003, 03:24 AM -
Alpha 8942 air flow direction
By bill1971 in forum Processors, Memory, and OverclockingReplies: 5Last Post: July 21st, 2002, 12:14 AM
that was easy, if only deleting the partition was that simple.
