Thread: Noobie Build Help.
December 17th, 2011, 11:12 PM #1Junior Member
- Dec 2011
- 1
Noobie Build Help.
This will be my first build and mostly I just want to make sure my products will be okay with each other and will fit together I will like all the hardware I would like to purchase and if I could just get some feed back not only on the build but if all the hardware is actually compatible I would really appreciate it!
Case: Newegg.com - Antec DF-35 Black Steel Computer Case
Mother Board: Newegg.com - ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
CPU: Newegg.com - AMD FX-4100 Zambezi 3.6GHz (3.8GHz Turbo) Socket AM3+ 95W Quad-Core Desktop Processor FD4100WMGUSBX
RAM: Newegg.com - G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
Power Supply: Newegg.com - CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Video Card: Newegg.com - SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
Hard Drive: Newegg.com - Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
December 18th, 2011, 12:36 AM #2
if your planning on running 2 6870's in crossfire down the road, I'd look at getting a board with the 2nd PCIe x16 slot with at least x8 bandwidth, this one only has x4.
If your only going to run a single card, then that 750W PSU is way overkill, you'd be fine with a 500-550W range PSU.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
Hi from Canada, another noobie!
By thorinator in forum IMO CommunityReplies: 6Last Post: December 21st, 2008, 12:11 PM -
Trying to reformat... I'M A NOOBIE!
By mjolnir1134 in forum Applications and Operating SystemsReplies: 6Last Post: September 1st, 2005, 11:19 PM -
two noobie problemos
By capybara in forum Linux and UnixReplies: 2Last Post: August 8th, 2004, 07:51 PM -
new noobie hello
By KungpowChIkEn in forum IMO CommunityReplies: 20Last Post: December 21st, 2003, 09:33 AM -
SCSI noobie...
By sKiT in forum Storage RelatedReplies: 7Last Post: March 14th, 2003, 06:01 PM
I stayed up all night watching Japanese cartoons and didn't get up until 3PM. But I just got back indoors after that, so I spent about six hours out in the sun. It was a little humid, but nice...
