Results 1 to 4 of 4
    20
    Phase One of Project Element-Xero Complete! (PICS)
    Masked off and measured. I used a novelty checker piece tangent to the corner lines to make the rounded edges.
    http://www.testequipmentdepot.com/mi...edmeasured.jpg
    Cutting....
    http://www.testequipmentdepot.com/mi...withdremel.jpg
    Hole cut and window mounted...I also sanded the back of the panel to a brushed aluminum finish for optimal light reflection....
    http://www.testequipmentdepot.com/mi...mandattach.jpg
    The panel front...
    http://www.testequipmentdepot.com/mi...dinstalled.JPG
    The door won't close because the plexi doesn't clear the support beam in the frame (or the PSU rack)!
    http://www.testequipmentdepot.com/mi...upportbeam.jpg
    http://www.testequipmentdepot.com/mi...ightlyajar.jpg
    So I had to dremel out that sucker and take a quarter inch off the PSU rack. Fits nicely now!
    http://www.testequipmentdepot.com/mi...s/DSCF0022.jpg
    http://www.testequipmentdepot.com/mi...s/DSCF0023.jpg
    A sloppy sampling of the future glory of my lighting
    http://www.testequipmentdepot.com/mi...s/DSCF0025.jpg
    http://www.testequimentdepot.com/mis...s/DSCF0028.jpg
    http://www.testequipmentdepot.com/mi...s/DSCF0029.jpg
    Registered User
    4,097
    Nice work, keep us informed on the progress of your project
    Senior Member tarpat1's Avatar
    Pitman, NJ
    703
    Nicely done, keep the pics coming!!
    Member CrazyCase's Avatar
    Sep 2002
    188
    Nice colors in the window. I like the look it makes on the black outside. you thinking of adding an etching or something else to it still?
