Results 1 to 6 of 6
Thread: side window Q!
    Senior Member nurdonsite2's Avatar
    Jan 2003
    Mississauga, Ontario
    604
    side window Q!
    what would i use for putting in a side window in my case? plexiglass or lexan? or something else? and do i put it in from the inside? and how?
    thanx for ur help.
    Ultimate Member davidamarkley's Avatar
    May 2002
    MO
    2,353
    Well, most of the time I hear about people using plexiglass, cheaper than lexan (I think) and you don't need it to be THAT strong!
    And, alot of people have used car molding, but, you might go to newegg.com, or cyberguys.com and look at their window kits, you'll get a good idea of what they come with. I've never done one from scratch, but have used the kits from cyberguys($10) and they work fine.
    I've still got the instructions from my kit if you wanted them. I could PM what it says on there. Just LMK...
    David
    Jan 2003
    604
    yeah that would be great.
    thanx
    norml.org thekingofpain's Avatar
    SoCal
    5,434
    Get the cheap setup like Dave suggests---simple to install, difficult to mess up---
    Ultimate Member Idigguns's Avatar
    Oct 2002
    S. Florida
    1,324
    Plexiglass definitely! Lexan scratches too easily. Check out my site for some tips.
    RicheemxX
    Guest
    PCmods.com they ahve some side windows on sale click on the moving sale link and go to page 2.
