Results 1 to 12 of 12
    Dec 2001
    3
    Question AT 8MHz case to 1.0 + GHz
    Has anyone ever attempted to modify an original AT case to accomadate an ATX board? This is what I want to do.
    If anyone has done this do you have any pictures?
    How did you go about doing it?
    Do I need to chop a good ATX case and use the back plate?
    Do you know where to buy a replacement plate that can be attached to the case?
    HELP!!
    norml.org thekingofpain's Avatar
    SoCal
    5,434
    Must be a GREAT case if you wanna reuse it---abit of time, energy and a couple bucks may/will be needed for the swap...
    (Id just buy a new case, there are MANY new atx cases available cheaply, local computershow item here, can be had as cheap as 20$ w/powersupply)
    Dec 2001
    3
    Well its not really a good case it is just a project that I have taken on to try to out do a friend of mine in a game of whacked cases.
    I think that the main thing that I am looking for is a maybe a rack mount case back plate for an atx form factor.
    Another possibility that I may consider is an AT board that will support t-bird.
    Anyone know of such a beast?
    Dec 2001
    Grand Rapids MI
    3
    PC-Chip makes a AT t-bird/Duron MOBO but it's only 200Mhz FSB and they are hard to find in the U.S.A. also they have on board Video and sound and no agp slot so your best way is to rework a AT case to ATX . I have re-work a old 1983 Gateway 2000 486/DX2 33mhz to a atx but it's takes lotts of time to do and you we not save any money to do it right
    But wen they see it labeled 486/33 and it blows their P4 away you don't tell them it's a T-bird 1.4 under the cover !! plus it's my late Fathers old case (sure do miss dad now) so will always keep the case for my life time! BUT IT DON'T HAVE TO BE SLOW INSIDE.
    Ultimate Member jadison's Avatar
    1,461
    I have some info on case mods for an AT case, this is when I was a bit new to the case mod. business...hehe
    Check it out HERE
    Boy, that was a long time ago...
    -=jd=-
    Banned by everybody Ultima's Avatar
    5,077
    For me it was very simple.
    I just cut out the back piece where normally there are the throughput thingies that make the case AT.
    Once that was gone, I used those plastic spacers to put the mobo on the backplate, ther was 1 screw hole, so I used it, and now it houses my Abit KT7-raid mobo with everything on it.
    Only thing you'll need to buy, if ya haven't already, is an atx PSU.
    Ultima
    Dec 2001
    3
    Post
    Closer, is there any chance that yall would have any pics that I can see to help me on my journey?
    k8vol you got the idea, that is exactly what I want to do.
    I want to have people to come over to the house and ask to surf the web, get on the HP pavilion and laugh at me cause I got an old at machine around still untill I turn it on and it is running win2k.
    XT
    XT is offline
    Member XT's Avatar
    Jan 2002
    'Burbs of Buffalo NY
    185
    a 1983 Gateway 2000 486/DX2 33mhz ??
    i hope thats the model #! i wasnt aware 486's were around in 1983 hell i bought my 4.77 mhz xt back then <G>
    Senior Member Rhino's Avatar
    552
    It's like that, and it's like this....
    Ultimate Member willy_ph's Avatar
    Trent University
    2,414
    That's some fine work on that old IBM from the link.
    Senior Member tarpat1's Avatar
    Pitman, NJ
    703
    That old IBM case rocks!
    Ultimate Member caddmannq's Avatar
    Clovis, CA
    2,647
    Hmmm...makes me want to "do" my old PS2 Model 50.
    That's pretty retro...If I could styff a flat panel TFT into the old B&W VGA monitor, that could be cool too.
    Also, I'm considering a Duron install into an old Apple Performa "pizza box" machine. That's a slim little deal, but ducted cooling or peltier would be a must!
