Thread: PSU Advice
July 10th, 2003, 07:45 AM #1Member
- Jul 2003
- Location
- United Kingdom
- 40
PSU Advice
Hi, i was wondering what psu to use for my future setup which is arriving tomorrow:
Microstar K7N2 Delta-IL Socket A Motherboard
128Mb GeForce FX5200 AGP8x Graphics Card
512mb pc2100 (may upgrade more to 1gb)
Athlon 2400+xp
and some case fans but havent decide what yet
Any advice on what power supply to use??
July 10th, 2003, 08:04 AM #2
You'd better get 350+Watts PSU from a quality maker ... Enermax, Antec and Aopen make solid reliable PSU.
Regards
July 10th, 2003, 08:28 AM #3Member
- Jul 2003
- 31
Agreed. I just built an AMD 2000 Machine, and one thing I've learned from responses to my posts's here, is that typically AMD's run a bit warmer than Intel for whatever reason, so when you do use the superior
AMD processors, the fans and PSU are important.
Goodlucks
July 10th, 2003, 08:47 AM #4
Are you going to be oveclocking? If so you'll need a better heat sink and fan than comes standard with the 2400 also. Kenkun is right about the branded psus. What's the price range you're looking to stay in?
July 10th, 2003, 09:07 AM #5Member
- Jul 2003
- Location
- United Kingdom
- 40
not sure about overclocking yet so maybe not.i got £20-30 to spend on a psu
July 10th, 2003, 09:09 AM #6
I've never had any problems with the 2 cheapo PSUs that've come with my cases but a few (6) months ago i upgraded form an Athlon 650 to a nice XP2200 and decided to get a "good" PSU jsut to be safe, i scored an Antec 400w Smartpower from CompUSA for around $45 and i've been nothing but happy... Antec makes good stuff and they're pretty inexpensive. I've also heard great thing about PC Power & Cooling supplies though i dont know how they price
PeACE
-=LuNCH
July 10th, 2003, 09:14 AM #7
As far as the o/c goes, you can always get another cooler later so no biggie. Good luck in the search.
July 10th, 2003, 09:30 AM #8Member
- Jul 2003
- Location
- United Kingdom
- 40
i think im going to buy a 400w psu
Rather naive in the extreme to go to Communist China--even if a 'special territory' thereof --to hide. An act he will doubtlessly regret as he becomes a pawn.
Why should we Pardon Snowden?
