Results 1 to 9 of 9
    Jul 2003
    Minneapolis, MN
    545
    Question LCD monitor size (length and width)?
    I'm looking into building a custom case with an LCD screen mounted right into it. Right now I'm just designing it and I have a question for those of you that have modded LCD screens...
    What is the length, width, and height of a 15" LCD screen? I'm not talking about the monitor, just the LCD component.
    WindowsXP Home
    Asus A7N8X-X
    XP+2800
    768 Mb RAM
    120 Gb Maxtor HDD
    52/24/52 Samsund CD-RW
    Pioneer 106 DVD-RW
    Nothing To See Here butch81385's Avatar
    Jul 2003
    PA
    15,108
    im not sure about the actual dimensions, but i will warn you about this: lcd monitors can create a lot of heat if place inside your case... that is what stopped me from doing this (and the fact that i couldnt just rip open and expensive item)
    I don't like signatures.
    Senior Member tmx468's Avatar
    Nov 2002
    Surrey, England
    836
    Unlike the Larger Monitors, a 15" TFT is indeed 15" diagonally across. It therefore measures roughly 12x9 inches (length, height). Unsure on the width though, as I have never taken one of those bad boys apart...
    Jul 2003
    Minneapolis, MN
    545
    I'm not real worried about heat. The monitor is going to flip open similar to a laptop, so when it's on, it won't be inside the case. As for the expensive part, that's what ebay is for. I'm going to try it on a piece of junk first, then if it works well, I'll go for better.
    WindowsXP Home
    Asus A7N8X-X
    XP+2800
    768 Mb RAM
    120 Gb Maxtor HDD
    Pioneer 106 DVD-RW
    Ultimate Member Droppyale's Avatar
    Dec 2002
    1,964
    Wouldn't it depende on the manufacturer?
    Jul 2003
    Minneapolis, MN
    545
    The width realy isn't a big issue, I can deal with that afterwards, I just wanted to know how big to make the opening...Thanks!
    WindowsXP Home
    Asus A7N8X-X
    XP+2800
    768 Mb RAM
    120 Gb Maxtor HDD
    Pioneer 106 DVD-RW
    Jul 2003
    Minneapolis, MN
    545
    I don't know, I'd figure that there'd be some sort of standard.
    WindowsXP Home
    Asus A7N8X-X
    XP+2800
    768 Mb RAM
    120 Gb Maxtor HDD
    Pioneer 106 DVD-RW
    Jul 2003
    PA
    15,108
    so are you basically making a laptop with the components of a desktop? please do tell specifics!
    Jul 2003
    Minneapolis, MN
    545
    Not really. Ever see those tool boxes where the top flips open...
    WindowsXP Home
    Asus A7N8X-X
    XP+2800
    768 Mb RAM
    120 Gb Maxtor HDD
    Pioneer 106 DVD-RW
What is 10 and 5 added together?
