Wrong CPU info, and overclocking speeds.  | | |
August 1st, 2004, 08:52 PM
| | Banned
I have an AMD Athlon XP 3200+, I overclocked it to 166mhz, but when I loaded the comp, it shows i have a 3000+. What happened?
And in my nvidia utility, I can change the AGP bus speed. Should I? and to what?
Also, i have 512mb DDR400 pc3200 ram, should I overclock that?
How do I up the voltage? |
August 1st, 2004, 09:08 PM
If you set an Athlon XP 3200+ to 166mhz it is UNDERCLOCKED, it should be set at 200mhz. Currently it thinks you have a 3000+ with your bus speed set at 166. |
August 1st, 2004, 09:12 PM
| | Banned
but it was originally at 100, I set it at 200 once and it shut down my computer. Do I need to turn up the voltage? |
August 1st, 2004, 09:29 PM
The voltage should be auto detected just fine seen that CPU is ment to be run at a 200Mhz(400DDR) bus. |
August 1st, 2004, 09:30 PM
| | Banned
well, should i try makign it go to 200 again? I dont want it to shut down on me again. |
August 1st, 2004, 09:51 PM
| | Banned
August 1st, 2004, 10:01 PM
No .. if your pc shutsdown when you overclock it you should return to a lower CPU speed if you want to use it  and you don't want to f.. the CPU .. i'm telling you this cos i fried a few already .. and it's not a nice feeling .. |
August 1st, 2004, 10:04 PM
| | Banned
well that means that my cpu is running under speed? Is it really supposed to do 200? That's the max. |
August 1st, 2004, 10:09 PM
if you are positivley shour that your CPU is 3200+ and that's what you bought and you just set the clock to 3200+ and doesn't work .. it means it' has a problem.. or if you donno for sure try to check that...
is it 3200+? or are you trying to a overclock a smaller one ? .. i for one last year i bought a 2200+ and got it overclocked upt to 2800+ but recently it reboots whenever it wants... so i had to downgrade to 2600+ ... |
August 1st, 2004, 10:10 PM
And no i never got it dooing 200 ... just 166 |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Basics for a 1Ghz | leokent | Processors, Memory, and Overclocking | 2 | July 25th, 2004 03:59 PM | | Overclocked AMD xp 2500 (Barton) | Tecplay2 | Processors, Memory, and Overclocking | 39 | July 12th, 2004 02:45 PM | | Overclocking stability question | covana | General Tech Discussion | 2 | February 12th, 2004 03:05 PM | | Overclocking XP 2400+/Epox 8KHA+/Crucial PC2100 possible? | s7ryk3r | Processors, Memory, and Overclocking | 4 | May 31st, 2003 06:50 AM | | p4s533 overclocking | NiTCOM | Motherboards | 3 | May 13th, 2003 04:48 AM | |
