CPU voltage problem?
Currently Active Users: 2107
Discussions: 200,948, Posts: 2,379,386, Members: 246,309
Old February 5th, 2002, 08:13 AM     #11 (permalink)
KenKun's Avatar
Well .. do you have the latest BIOS for your MoBo...? .. that could be fixed with BIOS update ..
KenKun is offline   Reply With Quote
Old February 5th, 2002, 08:41 AM     #12 (permalink)
Registered User
welcome!
make sure the current bios doesn't have any incompatability issue with raising the fsb. read the bios's information and see if there is. if there is, then update the bios. if it dud't, then i recommend you don't update it.
raising the Vcore alone may not help you overclock your memory. i'm not familiar with your board, but see if you can raise the memory voltage or Vdimm a notch or two. it may help you gain higher system bus speed.
your 1600+ may reach 145fsb-150fsb. after that you may need to unlock the processor and drop the multiplier a notch so that the processor may run at a comfortable operating spec.
btw, make sure you have the latest MBM. MBM usually does a good job with the voltage readings. just make sure your setting in MBM is set correctly according to the motherboard.
what does the voltage reading in the bios say?
regards
r0l0e
r0l0e is offline   Reply With Quote
Old February 5th, 2002, 08:43 AM     #13 (permalink)
Send a message via ICQ to Sakki
latest bios 3.3 installed, latest 4in1s installed but no good... i got this setup from december and whatever i do on it i cannot get past 140 fsb...
Sakki is offline   Reply With Quote
Old February 5th, 2002, 08:50 AM     #14 (permalink)
last time i checked the bios readings it was with auto vcore and if i remember well it was 1.68 to 1.73 and so i started checking if it is a voltage problem... i raised the DDR voltage too but it didn't help... btw many thanks to you guys for all your help these forums are the best i ever seen
Old February 5th, 2002, 08:59 AM     #15 (permalink)
KenKun's Avatar
Look .. i will tell you what had happened with me few days ago ..
I changed my HS from GlobalWin to TaiSol .. Temp dropped few degrees and everything was OK .. until i booted up into winXP .. it just crashed immediately ... i dropped the FSB to 145 and the same thing happened .. winXP couldn't run more than few seconds ...
I check again and everything was OK, the temp readings in BIOS were just fine ..
I Removed the HS and saw that the AS was all over the CPU .. .. also another thing, one of the CPU protecting legs was off ...
So i cleaned the AS with Acetone and plugged the leg once again .. put back the HS carefully ...
Booted up like charm after that ...
I know it might not be related but just double check if your HS is seated well .. and it would be better to take it off and check then re-attach ...
Regards
Old February 5th, 2002, 09:05 AM     #16 (permalink)
thanx for your info kenkun... i checked and re-checked the hs many times and i will check it once more tonight when i return home...
Old February 5th, 2002, 09:08 AM     #17 (permalink)
Registered User
this is what i got from reading about the low voltage.
MSI sets up their BIOS to allows +/- .1 volt variation from the nominal spec for the chip, which is also the max spec for the chip.
if you want more info, mail MSI tech. if you wanna try your luck, try downloading the 3.43 beta bios from MSI's site.
http://www.msi.com.tw/support/bios/b...K7T266+Pro2-RU
remember, MSI builds there board for stability not tweak-ability.
Making Health Care Worse (169)
The disrespect of Obama by Russian .. (22)
Is It Just Me? (2934)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
