Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
    Mar 2002
    Under Your Bed
    8,909
    Need quiet Athlon HS/Fan!
    Hey turtle people!
    Okay...for whatever reason, my ThermalTake Volcano 6CU+ has been loud since day 1 (although OuT swears his is quiet) and I really, really would like to replace it with a silent cooler. My temps never leave the 40's, so I need a quiet one that actually works.
    Related info...
    Soyo KT333 Dragon Ultra Mobo
    AMD Athlon XP2000+
    T-Shirt
    What the...how did that get in there???
    Thanks in advance!
    Mike
    Ultimate Member Ryanoffski's Avatar
    Jul 2003
    West Valley City, Ut
    1,202
    How's this?
    http://www.newegg.com/app/ViewProduc...106-037&depa=0
    21db seems quiet enough.
    /edit I like the shirt. They have those at a local store.
    Mar 2002
    Under Your Bed
    8,909
    Hey, nice cooler...going from 39db to 21db should be quiet nice!
    Have you ever used it or did you look up Thermaltake and sort by votes? (which I do a lot)
    Anyone know of any that aren't close to $30? Or is this one of those "you get what you pay for" items?
    1010011010 jmichna's Avatar
    Chicagoland IL
    3,249
    Martoch,
    You may want to check out the offerings from these guys: http://www.silenx.com/productcart/pc/mainindex.asp.
    I have no experience, but their products' reviews seem to come from legit sources. Their 600W silent PS and 120mm fans (58cfm @ 14dBa!) intrigue me.
    Mar 2002
    Under Your Bed
    8,909
    They do look cool, but they're a little pricey for me right now...$33.95 is the cheapest socket A listed. They do pride themselves on the quietness though, just wish I had a little more $$$ to spend on one.
    Dear Santa,
    I've been a very naughty boy this year, but I still want a HS/Fan for my AMD Athlon XP2000+ (it's OC'd). Don't you dare install it though, NOBODY touches my computer!!!
    Merry Christmas,
    Mikey
    Jul 2004
    919
    well if u want quite / good cooling get the Xp-120 , slap a nice 120 mm fan on there and u are set
    E8400 8.5x500=4250mhz 1.38v 24/7 ( 4.7-4.9ghz for benchs ) /Evga 780i
    OCZ PC-6400 5-4-4-15 800mhz 1.9v / Corsair 620hx / 8800gt @ 740/1800/1000 24/7
    Prof. of DooGlian Studies MegalosSkylaki's Avatar
    Nr. GroundZero NYC
    7,955
    Yo, Ryanoffsky
    How come TT don't list it's weight...all that copper..
    WHY is it a secret?
    Two kilos ?
    Nice fan, Mr.Newman !
    DOOGlANOFFSKY
    practically canada. bombledmonk's Avatar
    Aug 2003
    MN
    3,384
    Just to add to this conversation I had one of these installed on my OCed 2500 barton @ 2.2Ghz. http://www.newegg.com/app/ViewProduc...150-040&depa=0
    It kept things around 47 full load out of the box with included thermal paste. I then lapped it and put on some ArcticSilver 5 and that temp got down to 44 for a heatsink/fan that you can't hear unless your head is inside the case. (**I also have reasonably poor case cooling because I have my fans turned all the way down)
    Mar 2002
    Under Your Bed
    8,909
    Thanks bombledmonk, that's more in my price range...I'll have to check it out a little more, seems to be a great "bang for the buck" item.
    Jul 2004
    919
    @ as close to stock as i run this chip 2ghz (slowest i have every booted it ) it runs a 15idle and 19 load =) @ 2.7 ghz its only @ 39-45 load dep on ambient temp
    Sp-97 is also good , Spend Some $$ on ur hsf u will tank ur self later
    Aug 2003
    MN
    3,384
    Quote Originally Posted by ||Console||
    What are you talking about? In English please....
    Nothing To See Here butch81385's Avatar
    Jul 2003
    PA
    15,092
    translation:
    if you buy an expensive heat sink like he did, you will be very happy with the results. when he runs his processor near stock speeds (which isnt usual because he is a heavy overclocker) it is very cool... even at .7ghz higher than that he can still keep it reasonable
    Ultimate Member rabidaardvark's Avatar
    Jul 2004
    right here
    2,443
    Quote Originally Posted by bombledmonk
    Though that has to be one magic cooler to hit 15 on air.
    size=1 rocks
    Aug 2003
    MN
    3,384
    LOL, thank you butch.
    Console.... but how can you run 15C idle? That would mean your room would have to be below 15C because you cannot cool below ambient and that's pretty darn cold to be sitting at a computer.
  15. #15
    Jul 2003
    1,202
    Quote Originally Posted by Martoch
    This is the HS/fan my brother- in-law bought when I helped him build his computer last week. I'm using a volcano 11 Xaser, and it's only quiet if the fan is set to low.
    Yo, Ryanoffsky
    WHY is it a secret?
    Two kilos ?
    DOOGlANOFFSKY
    They leave it up to your imagination! Just think of it as light as a feather.
  16. #16
    Jul 2004
    919
    I live in canada , it is 0 deg and lower , i dont mind the cold , Most of my windows are open in my appamerent . It prob like 10 deg in my app =)
  17. #17
    Ultimate Member SpaceSquad's Avatar
    Nov 2004
    Ottawa, Ontario
    2,742
    holy crap dude. I live in Ottawa, but I don't live in an igloo like you do. Wow, but it does wonders for cooling
  18. #18
    Mar 2002
    Under Your Bed
    8,909
    Wowza, that's freezing!!! It was in the mid 70's here in FL today.
    Thanks for the suggestions...I think I'm going to go with the Thermaltake SILENT BOOST. The reviews are fantastic and I guess I'll fork up a little extra $$$ for a high quality product.
  19. #19
    Jul 2003
    1,202
    Can't go wrong with that. I've always liked Thermaltakes.
    This high today was 32F (freezing) but it's been so windy today!
  20. #20
    Mar 2002
    Under Your Bed
    8,909
    Ordered it...along with a tube of Arctic Silver 5!
    Thanks again...I'm tired of having to turn my computer off at night so I can hear my son calling me at 5am from his room...if I don't get there right away, he wakes everyone else up.
  1. Quiet cooling suggestions
    By prexaspes in forum Processors, Memory, and Overclocking
    Last Post: April 10th, 2003, 07:31 PM
  2. CPU for Design and PDF...
    By Winos2Mac in forum General Tech Discussion
    Last Post: December 25th, 2002, 07:24 PM
  3. I think I got a good deal on a Dell.
    By no1_vern in forum General Tech Discussion
    Last Post: November 5th, 2002, 07:41 PM
  4. A Silver Heatsink???
    By Ritalin Kid in forum Processors, Memory, and Overclocking
    Last Post: April 12th, 2002, 11:56 AM
  5. Anyway to reduce Fan Niose?
    By Linkin' Park in forum General Tech Discussion
    Last Post: March 5th, 2002, 02:19 PM
