Results 1 to 2 of 2
    Dec 2004
    60
    question on processor speed and oc'ing
    i have a amd athlon xp 2500 (barton) that is supposed to be a 1.8ghz processor but went to the control panel -> system and it says 1.2 ghz. Do i need to go into the bios and change something. if so what? thanks. I need to get a better speed out of this processor.
    Asus A7V600
    1GB PC 3200 DDR (400mhz)
    AMD Athlon XP 2500 barton core
    80gb 7200 rpm
    ext. 80gb Firewire Drive
    128mb ATI 9600 AIW
    thank you.
    1010011010 jmichna's Avatar
    Chicagoland IL
    3,249
    Sounds like your CPU's bus speed is running at 100mHz... or else the CPU multiplier is not set at default... BUT
    Before you do anything, however, download a program like "WCPUID" or "CPU Z" or "Computer Brain ID" and see what speed they say your CPU is at. Also, try to catch the CPU's speed early on during the POST display... see what that says.
  1. wow great price for a new Ti4200 !!
    By sweeper2 in forum Graphics Cards and Displays
    Last Post: September 23rd, 2004, 11:23 PM
  2. FSB speed
    By lewis_c in forum Processors, Memory, and Overclocking
    Last Post: July 28th, 2004, 03:27 PM
  3. Understanding CPU clock rates & Multipliers
    By neillsmob in forum Processors, Memory, and Overclocking
    Last Post: February 24th, 2004, 02:04 PM
  4. Flashing Bios
    By xestanz in forum Technical Support
    Last Post: February 1st, 2003, 04:24 PM
  5. k7 vs Athlon XP - what's the difference
    By screen in forum General Tech Discussion
    Last Post: September 25th, 2002, 06:01 PM
