Page 2 of 2 FirstFirst 1 2
Results 21 to 32 of 32
  1. #21
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    Quote Originally Posted by NightRise420
    Okay....It's your Ram....You have a PC4000 Geil memory. That memory isn't a TCCD chip i believe. So u can't have CL2 and have high bandwidth.
    Try this, set the timing to 3-4-4-8 then keep setting the FSB until it stops.
    Also try to up the vdimm.
    i set it to 2.5 and its at 2,5ghz atm running nicely..
    thnx for the help
    EDIT: At 11x240mhz = 2,64ghz my comps keep freezing.. i bumped up the voltage .7V up to 1.47V... is that the problem? should i go higher? I also bumped the ram voltage up by .1V
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
  2. #22
    Warsaw, Poland
    6,443
    bump... could use pr0 advice
    its my first time
    BigWater SE
  3. #23
    Full Time WoW Addict nwo75200's Avatar
    Jan 2004
    Cleveland, OH
    8,571
    go higher with the CPU (vcore) voltage, take it to at least 1.55.
    set the HTT from x5 down to x2, this will not decrease performance
  4. #24
    Banned pphalan's Avatar
    Nov 2004
    BACK in the USA
    1,823
    How about a board and AMD processor that can be overclocked easily? Im looking for some suggestions.
  5. #25
    Jan 2004
    Cleveland, OH
    8,571
    Quote Originally Posted by pphalan
    MSI K8N Neo 2 Platinum s939
    AMD A64 3000+ s939 Winnie
    should OC nicely to 3700+ speeds
    If you're interested, I'll give you links if needed.
  6. #26
    Nov 2004
    BACK in the USA
    1,823
    Yes Im interested, I have $6000 to spend on new equipment, they will be runnig FAD like Vikeor
  7. #27
    Jan 2004
    Cleveland, OH
    8,571
    Arrow
    Like I said, A64s are definitelly NOT the CPUs for FAD, they're for intense multimedia, multitasking, and gaming use, NOT FAD.
    Get a good socket A mobo, and OC a 1.8GHz duron to at least 2GHz. Like I said before, FAD could care less if your PR is 5000+, but if the 5000+ is running at 2GHz, a Duron will score just as many points as the 5000+
    if you're looking for multiple systems then go with this combo:
    mobo:
    http://www.newegg.com/app/ViewProduc...138-227&depa=1
    or
    http://www.newegg.com/app/ViewProduc...135-143&depa=1
    note that nf2ultra is definitelly better for OCing (IMO)
    CPU 1.8GHz Duron:
    http://www.newegg.com/app/ViewProduc...104-160&depa=1
    and steal this RAM
    http://www.newegg.com/app/viewProduc...223-009&depa=1
    If you wanna build one of these for your personal use:
    CPU A64 3000+ s939 winnie:
    http://www.newegg.com/app/ViewProduc...103-499&depa=1
    MSI K8N Neo2 Platinum:
    *** it I forgot about this amazing DFI mobo:
    http://www.newegg.com/app/ViewProduc...136-152&depa=1
  8. #28
    1010011010 jmichna's Avatar
    Chicagoland IL
    3,249
    Vikeor,
    My experience with Geil ram is it likes more voltage to imrpove stability, especially when overclocking. I normally (always) run Geil +0.20v over default, and when pushing an overclock, even +0.30v.
    jmichna
  9. #29
    Nov 2004
    BACK in the USA
    1,823
    Quote Originally Posted by nwo75200
    mobo:
    or
    CPU 1.8GHz Duron:
    and steal this RAM
    Thanks alot, for basic crunchers I can set up several pretty cheap. my personal Ive been looking towards a dual processor, 3phase Ac load calculations are complicated sometimes plus I want one that can handle all games out there. Thanks again, thats some good basic crunchers at a real good price.
  10. #30
    Warsaw, Poland
    6,443
    Quote Originally Posted by jmichna
    Vikeor,
    jmichna
    alright thnx alot... ill give that a shot
    BigWater SE
  11. #31
    Warsaw, Poland
    6,443
    what does decreasing the HTT do?
    BigWater SE
  12. #32
    Jan 2004
    Cleveland, OH
    8,571
    Quote Originally Posted by vikeor
    recudes the hyper threading link or w/e, which is pretty much useless if it's over 1GHz.... but w/e it gives you a lot more OCing stability when you reduce it
  1. please help
    By away23 in forum Technical Support
    Last Post: November 28th, 2004, 12:06 AM
  2. Links leading to wrong threads
    By Bizkitkid2001 in forum Suggestion Box
    Last Post: May 21st, 2004, 10:10 AM
  3. Plug & Play Issues With WinXP Pro
    By hifi in forum Applications and Operating Systems
    Last Post: January 30th, 2003, 09:25 PM
  4. HELP! - Geforce 4 Trouble on Intel Motherboard
    By snisker in forum Graphics Cards and Displays
    Last Post: November 24th, 2002, 12:52 AM
  5. Modem Problem
    By TontoRodrigues in forum Networking and Internet
    Last Post: March 7th, 2002, 09:59 AM
