Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 43
    Senior Member Micky758's Avatar
    Jan 2005
    UK
    541
    What cooling are people using?
    Just wondering what cooling and fans people are using:
    Cooling on the Fan-O-matic (TM)
    CPU HSF: Themaltake SlientBoost K7 heatsink with Tt coolmod 2 fan
    northbridge: Zalman heat sink
    GPU: Vantec Iceberq 4
    RAM: Tt 40mm fan
    Akasa LED 80mm X4 case fans
    Akasa HDD coolers X2 (x2 60mm fans per cooler)
    Member RamAirTA98's Avatar
    Apr 2005
    In the OK
    117
    I have an aluminum case for starters.
    CPU: Gigabyte 3D Cooler-Pro w/arctic silver 5
    northbridge/southbridge: stock ASUS heatsink
    GPU: Stock Albatron 6600GT HSF (Massive!)
    Plus, 2x60mm fans blowing on bottom of card
    And, exhaust blower on top of card to remove excess heat from case
    RAM: Stock Corsair PRO HS w/status LEDs (Love this HS...)
    Case: 2x120mm fans (1x intake, 1x exhaust)
    PSU: Antec 430W TruePower 2x80mm (1x intake, 1x exhaust)
    HD: 2x60mm (Only on the Raptor)
    Edit-
    CPU temp: 38°C (P4 Prescotts suck!)
    MoBo temp: 24°C
    ASUS P4C800E-Deluxe
    P4 3.2Ghz @ 3.8Ghz 42C Idle
    1GB Corsair TWINX3200XLPRO @ 952Mhz
    Jan 2003
    Milwaukee, WI
    7,657
    Quote Originally Posted by RamAirTA98
    what does having an aluminum case have to do with the cooling?
    Not trying to be facetious or anything, its just that the material of the case has basically nothing to do with heat variances unless it serves to impede airflow or insulate specific components...
    Onii-san Bizkitkid2001's Avatar
    Sep 2002
    San Antonio
    10,929
    I have an Alluminum case, the Cooler Master Stacker.
    CPU: Vantec Aeroflow 7 w/ generic thermal paste.
    GPU: Stock Evga 5900 NU
    Case: 2x120mm fans (1 intake, 1 exhaust)
    2x80mm fans (1 exhaust top, 1 intake side)
    Hard Drives (4 drives): 16x30mm fans (yes, 16 fans, all intake)
    PSU: Foxtronn 450 watt 1x80mm (exhaust)
    Thermal Take 420watt 2x80mm (1 intake, 1 exhaust)
    So thats 25 fans total.
    Temps right now are: 48°C CPU 100% load
    35°C Case
    My temps suck because its warmer in my room (already summer here down south) and its been a long time since i have cleaned my computer. (I can see dust on my front drive bezels infront of the 120mm intake fan, hehe)
    DPA
    DPA is offline
    Ultimate Member DPA's Avatar
    Oct 2002
    KCMO
    2,020
    JPMiller, a case made of goose down feathers would capacitate a higher ambient temperature than a case of aluminum. While not hardly worth the premium paid for an aluminum case, there is an inherant advantage present in owning an aluminum case - temperature wise.
    I personally cool with an SLK900 copper heatsink and a 92mm fan, nothing else.
    (AKA) Nakamura sweeper2's Avatar
    Nov 2003
    5,737
    cpu----Arctic Cooling 2L HSF (80mm)
    9800----Arctic Cooling VGA Silencer Rev.3
    PSU---3 fans (2 intake, 1 exhaust)
    case----rear 120mm exhaust, front (w/filter)120mm intake
    passive HS on MB
    no cooling on ram
    quiet, cool, nice....
    Temps:
    Motherboard-- 29C
    CPU------------- 43C
    Aux-------------- 35C
    HD--------------- 16C
    room temp: 73F
    Jan 2003
    Milwaukee, WI
    7,657
    Quote Originally Posted by DPA
    JPMiller, a case made of goose down feathers would capacitate a higher ambient temperature than a case of aluminum. While not hardly worth the premium paid for an aluminum case, there is an inherant advantage present in owning an aluminum case.
    Thats exactly what I said...
    What exactly is the inherant advantage?
    DPA
    DPA is offline
    Oct 2002
    KCMO
    2,020
    see edit beforehand
    Literally and basically, aluminum has a better heat conductive capability than the standard steel frame case. Thus heat can be absorbed and dispursed through both ventilation and the case physically in an aluminum case better than a "low end" steel case.
    Ultimate Member [Neo770]'s Avatar
    Gold Coast,Australia
    2,477
    Volcano 9 on my CPU and a few case fans. Everything else is stock cooling.
    (o'.')
    Jan 2003
    Milwaukee, WI
    7,657
    OK...
    explain the advantages of cooling when using an aluminum case VS a steel case...
    sorry for highjacking this thread...
    I'll bump an old post that covers this...
    DPA
    DPA is offline
    Oct 2002
    KCMO
    2,020
    JP:
    again, just for further enforcement of the aluminum > steel case ideal, remember that we have yet to be "graced" by steel heatsinks, aluminum possesses much greater heat conducting properties than steel, but is obviously much more expensive and much less durable. Therefore, just save yourself the money and buy a steel case guys, you'll never notice the difference.
    Ultimate Member HeadBand's Avatar
    Dec 2003
    3,990
    i have pretty much have stock cooling...4 extra case fans though
    oh yeah i just put an iceberq 4 on my video card as the stock cooler went out last friday....right before a lan party
    btw it is a myth the aluminum is cooler than a steel case
    Hey who turned sigs on?
    Apr 2005
    In the OK
    117
    JP:
    LMAO about being "graced" by steel heat sinks... Aluminum dissipates heat much greater than steel. The ambient temp in the case will get dispersed through the aluminum easier. Granted, it isn't A LOT of difference, it does help by a few degrees...
    ASUS P4C800E-Deluxe
    Sep 2002
    San Antonio
    10,929
    thats what he just said.
    echo, echo, echo.................echo...................
    he said "graced" sarcasticaly.
    I like the looks of silver alluminum cases. I got the Stacker, not cause it was alluminum, but just because it had what i needed. The bad ass looks and shiny silver alluminum body just came along with it
  15. #15
    Apr 2005
    In the OK
    117
    I am aware that it was sarcastic...
    ASUS P4C800E-Deluxe
  16. #16
    Banned by everybody Ultima's Avatar
    5,077
    Cpu: Thermalright XP-90
    ram: Thermaltake copper heatspreaders
    videocard: ATI silencer 5
    Then I have 3 80mm blue cold cathode fans, 2 normal 80mm fans.
    In my PSU there are 2 fans I think. 1 120mm intake and 1 80mm to blow out of the case.
  17. #17
    Full Time WoW Addict nwo75200's Avatar
    Jan 2004
    Cleveland, OH
    8,571
    Main Rig:
    CPU: GIGABYTE 3D Cooler-Ultra GT
    GPU: stock (Leadtek 6800) looks too nice to replace.
    mobo: all stock
    RAM: Kingmax heatspreaders that are stock
    case: Arctic-Cooling Arctic Fan 3 80mm x2 exhaust
    1 80mm TT in the front.
    PSU: 2x80mm fans
  18. #18
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,193
    4
    personal (non gaming rig )
    CPU: CoolerMaster X Dream III 80mm 21dba clear with 4 blue Leds
    GPU: Thermaltake Highest performance all copper cooler w/ blue led for gf4 ti series
    Mobo: stock MSI heatsink
    RAM: none at the momen
    case: 2x 80mm fans on lower left panel, and 1x 60mm in read (i need a new case SOOO bad)
    PSU: 1x 80mm exhaust in rear
  19. #19
    Member Messiah89's Avatar
    Jan 2004
    Jupiter, Florida
    358
    CPU: Stock
    GPU: Stock
    Mobo: Stock
    RAM: None
    Case: 1x 80mm intake side case fan, 1 80mm exhaust rear case fan
    PSU: 1x 80mm intake front, 1x 80mm exhaust rear
    Heh...
    AMD Athlon 64 3000+ @ 2GHz
    Gigabyte GA-K8NSC-939
    Corsair 1GB PC3200 DDR RAM
    Maxtor 120GB 7200RPM Hard Drive
    XFX GeForce 6600GT 128MB AGP
  20. #20
    Jan 2004
    Cleveland, OH
    8,571
    Stocker ^^^^^^
  1. Hello people.
    By Kli'Klik in forum IMO Community
    Last Post: May 5th, 2004, 01:06 AM
  2. Hello People.
    By tecy in forum IMO Community
    Last Post: April 11th, 2004, 06:45 PM
  3. I tell ya, some people.
    By jkrohn in forum IMO Community
    Last Post: March 31st, 2004, 01:14 PM
  4. since so many people are here.....
    By Sweet in forum Suggestion Box
    Last Post: February 2nd, 2004, 04:16 PM
  5. All UD people, Need Help
    By msterzer in forum Distributed Computing
    Last Post: January 26th, 2002, 06:25 AM
