Thread: cpu cooling
June 9th, 2005, 07:26 PM #1Member
- May 2005
- 133
cpu cooling
what can i use that is around the house to cool my cpu? i got a 14 inch fan on it right now but its just not cutting it..any ideals thanks
June 9th, 2005, 07:49 PM #2Ultimate Member
- Mar 2005
- 1,789
dust it(your whole computer and mainly your heatsink/fan)
or put it in a freezer
well is it really that hot
also if your room or house is really hot then blowing hot air on it won't help much
a good dusting can help A LOTLast edited by mateo leet-o; June 9th, 2005 at 08:17 PM.
June 9th, 2005, 08:15 PM #3
Wow, what do you have in there that you can't cool with a 14in fan?
June 9th, 2005, 09:25 PM #4Member
- May 2005
- 133
my whole computer lol..my temps are like 159F on load with fan and 120F on idle with fanand.. it is only 74 degress in the house right now wish it was like 57 i like it cold lol. will putting it in a frezer mess anything up lolololol
Originally Posted by EXreaction
June 9th, 2005, 09:35 PM #5
How long has your pc had these temps. Is it a new build? Is there thermal paste on the cpu? What kind of heatsink and fan do you have?
June 9th, 2005, 09:49 PM #6Member
- May 2005
- 133
these temps have been here for about a year even after i dust it,i have paste on the heat sink and cpu,stock heat sink and fan plus a 14 inch metal fan blowing in it
June 9th, 2005, 09:55 PM #7
What cpu do you have? I think I would invest in a new heatsink and fan and use a thin layer of Artic Silver 5 on the cpu.
June 9th, 2005, 09:57 PM #8Member
- May 2005
- 133
i got a intel p4 2.4ghz cpu,were can i get this Artic Silver 5 will it drop my temps at all thanks for all your help
June 9th, 2005, 10:18 PM #9
You can get AS5 at any computer store. I would also look into getting a new HS/F.
Something like a Vantec Aeroflo. Your temps are way too high. I built a system last week using a P2.4 and it idles at 102° F and didn't get much over 118° F under load and this is with the stock HS/F.
I think first though I would just try the AS5. Remove the old paste with 90% alcohol, wipe it clean with a lint free cloth, then apply a thin layer to the cpu.
June 9th, 2005, 10:31 PM #10Member
- May 2005
- 133
ok i will do that thanks again
June 9th, 2005, 10:54 PM #11
Well sounds like something ain't right, I had a 2.4 a while ago but I used the stock heatsink and it cooled it just fine... anyway try the as and see what happends if the temps go down only a little that is a good first step. I would recommend a good heatsink such as a zalman heastsink(if it fits) or a thermaltake polo one I have have and keeps my p4 E 3.0ghz 48 load and 41 idle.
Jambalaya
June 9th, 2005, 11:03 PM #12
Maybe your heatsink wasn't on right. Loose heatsink=high temps.
June 9th, 2005, 11:24 PM #13
take it out and clean the dust out, dont feel bad i got a 10in. fan blowing in my computer too
cuz all my stuff gets really hot (case sux)
June 10th, 2005, 12:07 AM #14Member
- May 2005
- 133
alright i will do that my case suck to lol
June 10th, 2005, 12:14 AM #15
How many case fans do you have? You should have at least 2. One pulling air in at the bottom front and one blowing air out in the top back. This is not your immediate problem though since you have these temps with a 14" fan blowing on the cpu.
June 10th, 2005, 01:08 AM #16Member
- May 2005
- 133
i have 6. 2 in back 2 in top and 2 in front
June 10th, 2005, 06:40 PM #17Since you have a big fan blowing on it mae sure that the case fans are all blowing out, otherwise your big fan would blow in and your case4 fans would blow in, and the air would not circulate. That could be why the temps are so high.
Originally Posted by noobhere
Otherwise, see if you can get all the fans blowing in the right direction so that the side could be put on. If it is done right I would imagine that the temps would dropp with the side on if the fans circulate the air right."The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
June 10th, 2005, 09:22 PM #18Member
- May 2005
- 133
well i made my fan all blow air out but still didnt work oh well
June 10th, 2005, 10:43 PM #19
Congrats on your 100th post!
Anyways, take off your heatsink and put Artic Silver 5 on it. And, maybe your heatsink wasn't on right.
June 11th, 2005, 01:06 AM #20Member
- May 2005
- 133
thanks reather, i will do the artic silver 5 after i find some around were i live so i wont have to wait for it lol
CPU Water Cooling
By muarrif in forum General Tech DiscussionReplies: 5Last Post: September 1st, 2004, 04:13 PM -
Computer cooling ^_^...and cpu
By perceptor in forum General Tech DiscussionReplies: 0Last Post: April 16th, 2004, 08:28 PM -
CPU Cooling
By ToddS in forum Processors, Memory, and OverclockingReplies: 13Last Post: June 27th, 2003, 05:33 PM -
Yet another CPU cooling thread...
By Mr. NoOne in forum Processors, Memory, and OverclockingReplies: 12Last Post: October 10th, 2002, 03:12 PM -
An idea for cooling a CPU...
By DemonKnight in forum Processors, Memory, and OverclockingReplies: 3Last Post: August 18th, 2002, 04:06 PM
you can go straight to sp3 from a clean install. No need to install the other service packs
