Thread: I think I have a temp problem
October 2nd, 2005, 04:45 PM #1
I seem to be running HOT , I thought I may have had a temp problem a while back but I have had a game lock up twice lately( Call of duty 2 Demo) and all I'm running is Fad (4 thinks) . So I got to checking the temps with Everst and in the bios. Both the same(daaa its running 70-78 celsius
) I need some thoughts what I can do to cool my cpu down. Heres my specs
Heres my MB http://www.giga-byte.com/MotherBoard...s_GA-7NNXP.htm
3200 Barton core Athlon Xp
1 gig of kingston 3200 ddr
80 gig seagate sata 150
Case is a black Knight with two 120mm fans blowing full blast (new case)
Heat sink is a copper volano 7 with a custom 80mm on it
recently used Ceramique paste by made Artic silver on the cpuPowered by area 51 Alien technology
October 2nd, 2005, 04:58 PM #2
have you made sure it's making proper contact?
reseat the whole thing and see if it goes downMain PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
October 2nd, 2005, 05:01 PM #3
Does sound like a badly seated heatsink or bad paste application, but you should also check your heatsink vanes aren't clogged with dust.
October 2nd, 2005, 05:53 PM #4
I see you're running FaD. Why don't you put it on snooze and see what happens... It's the first thing I'd do...
October 2nd, 2005, 05:55 PM #5
I just got it back up after re-seating the cpu and heat sink.
no luck .
heres my readingsPowered by area 51 Alien technology
October 2nd, 2005, 06:04 PM #6
Oh man its climbing to 80 c
October 2nd, 2005, 06:13 PM #7
it climbed up to 81c ,how hot can it go without frying my cpu ?
October 2nd, 2005, 06:16 PM #8
I was freaking out a bit, I shut a everything down running fad included and I have it down to 68 c. Wow surely its not 4 thinks doing that or something else?
October 2nd, 2005, 06:35 PM #9Member
- Aug 2005
- 45
first off at 82 degrees celcious ure computer would hmm how to be nice go kaboom?
how many fans u running, did u update bios, hmm, what else o yea, bad contact i garuntee u on the paste, u need to fix that, because at 82 c and climbing ure computer would fry out
October 2nd, 2005, 06:42 PM #10
Hmm...try having a house fan blow right into the case...though it could be from a bad sensor...
And how come you are running 4 thinks? Wouldn't it be better with just 1?"The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
October 2nd, 2005, 07:36 PM #11
I did some research a while back and found that gigabyte deliberaltly shows higher temps,how much? I don't know. As to 4 think I am pushing,cramming,crunching. Maybe an over kill going on. I am begining to think I need a new heat sink and some new paste the best I can find.
October 2nd, 2005, 07:47 PM #12
Make sure your paste is as thin as possible. The past is only to fill in the spots where the heat sink dosen't touch the CPU directly. As far as I know 1 think program runs your CPU at close to max, I don't think 4 can run it at more than that. The hottest temps I see is when I am running Think.
October 2nd, 2005, 10:51 PM #13
Before you look into new thermal paste, read this so you know how to do it right.
http://www.arcticsilver.com/arctic_s...tions_big2.htm"The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
Tried to delete temp Internet filesand... (difficult problem)
By PastranA in forum Technical SupportReplies: 0Last Post: June 22nd, 2004, 03:00 AM -
CPU Temp Problem?
By bluestorm2 in forum Technical SupportReplies: 4Last Post: June 7th, 2004, 10:47 AM -
PIII 650E overclocking - Temp. problem
By SSeven in forum Processors, Memory, and OverclockingReplies: 6Last Post: July 1st, 2003, 05:59 PM -
dumb question:Bios CPU temp vs Windows CPU Temp
By stamenkd in forum MotherboardsReplies: 3Last Post: February 21st, 2003, 02:16 PM -
CPU XP 2000+ Cooling Problem (temp too high)
By michael74 in forum Processors, Memory, and OverclockingReplies: 4Last Post: September 4th, 2002, 03:36 AM
Discuss Star Trek Into Darkness With Spoilers And Rate It Watch Iron Man 3 Online When asked about a Stefon movie, Hader said, “There’s no emotional through line. Sometimes people say to me, ‘I...
Mastered the art of seeming
