December 23rd, 2005, 07:04 AM
| 100mhz 128MB SDRAM or 133Mhz 64mb SDRAM?
Im not sure which one to use 100mhz 128MB SDRAM or 133Mhz 64mb SDRAM?
Thanks |
December 23rd, 2005, 08:15 AM
Well if you can't use both then use the 128 of 100 mhz. If things are that desperate then the extra ram will be worth a lot more than the 33 mhz.
__________________ size=1 rocks |
December 23rd, 2005, 08:22 AM
| | Let's go, Hokies!
| It depends completely on the system. You cannot just compare RAM speeds and draw a conclusion. If your system bus runs at 133 MHz, then any amount of 100-MHz RAM will slow things down. And if your system bus runs at 100 MHz, it won't run on certain high density 133-MHz RAM. |
December 23rd, 2005, 04:46 PM
yeah my system bus runs at 133 |
December 23rd, 2005, 05:01 PM
If you had 64mb of 133 it would be slower than 128 of 100. With 64mbs, the computer would spend so much time going back to the hard drive it wouldn't mater it is 33 mhz faster.
I'd use both also ,if you can.
December 23rd, 2005, 05:17 PM
| | Banned by everybody
you should be able to use both, the 133Mhz ram will just throttle back to 100Mhz and you'll have 192Mb 100Mhz ram in total.
Antec P180b, AMD X2 3800+ @ 2.7Ghz
DFI Lanparty Ultra-D, 2Gb DDR540
2 x 160Gb SATA, X1950XT 256MB
December 23rd, 2005, 06:07 PM
yeah but i also have a 256mb 133mhz ram in and i only have 2 slots |
December 23rd, 2005, 07:00 PM
| Quote: |
Originally Posted by RickyOyola yeah but i also have a 256mb 133mhz ram in and i only have 2 slots | That might be less of a clear choice. If your system is using more than 320mbs@133 running a program, I would think 384mbs @100 would be faster IF your system is not using more than 384mbs. If your system has to go to the hard drive things slow down more than a 33 mhz loss in the FSB |
| You may post new threads You may post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | what is better 2x128MB SDRAM 133Mhz or 1x256MB SDRAM 133Mhz ???? | ZAHYR | Processors, Memory, and Overclocking | 4 | March 26th, 2004 12:31 PM | | NEC 128MB 16x64 SDRAM | Oleg21 | Traders Forum: Buy, Sell, Trade | 3 | March 7th, 2004 01:10 PM | | FS 2 sticks PC-133 128MB SDRAM | MrLuigi | Traders Forum: Buy, Sell, Trade | 2 | March 27th, 2003 02:28 AM | | PC Chips AMD SDRAM/DDR SDRAM MOBO with onboard sound, LAN, and 56K modem | rourkchris | Traders Forum: Buy, Sell, Trade | 0 | February 7th, 2003 01:36 PM | | FS: 18 gig, 10 gig, 128MB SDRAM, 64MB SDRAM, Asus mobo w/ 500 AMD K6-2, RDRAM, CDRW | Computerfix | Traders Forum: Buy, Sell, Trade | 17 | May 14th, 2002 10:59 PM | | Most Active Discussions | | | | | Recent Discussions  | | | | | |
