help me decide
Currently Active Users: 1842
Discussions: 200,933, Posts: 2,379,201, Members: 246,299
Old March 29th, 2002, 02:44 AM   Digg it!   #1 (permalink)
help me decide
would like to change my heatsink and fan on my amd 2000+, i am in between the volcano 7 or the coolermaster HHC-001.
which one do you prefer? and why?
dar1again is offline   Reply With Quote
Old March 29th, 2002, 02:54 AM     #2 (permalink)
hifi's Avatar
Send a message via AIM to hifi Send a message via Yahoo to hifi
The only Co. I have had experiance with is ThermalTake....and after a bit of tweaking and some artic silver III, my Volcano 6+ Cu It has kept my 1900+ nice and cool...around 45-48 C ..... I have heard good things about the Volcano 7 as well.
Lian-Li PC1100 Plus
DFI-NF4 Ultra-D
A64 3700+ San Diego @2750 1.5Vcore
XFX GeForce 7800GTX
2X WD 74GB Raptors
OCZ PC-4000 VX Gold 4X512
hifi is offline   Reply With Quote
Old March 29th, 2002, 03:01 AM     #3 (permalink)
mickwish
Posts: n/a
I would go for the Volcano 7 as long as you check it fits on your board. Some boards (like Epox ones ) have capacitors and other stuff around the socket, which limits how big a HSF you can get on it.
Thermaltake make some great HSF's IMO.
Old March 29th, 2002, 03:10 AM     #4 (permalink)
KenKun's Avatar
I would go for the Volacano 7+ (Plus) .. if you are after top performing HS ..
If the cash is an issue .. then Volcano 7 should do fine ... and will keep your CPU in at a cool temp
HHc-001 CM HS is nice too, but the heat pipes might prevent proper seating (If your chipset fan is close to the socket like in EP 8KHA+ which i own) ....
KenKun is offline   Reply With Quote
Is It Just Me? (2889)
Wireless Televisions. (6)
Obama the Muslim (14)
Modern Warfare 2 freeze (12)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
