Results 1 to 12 of 12
    Oct 2007
    4
    help me processor upgrade?
    I might want to uopgrade a processor I know nothing...... can someone help me out by asking me questions so i can answer them? i have no clue what to do... i know mine is 2.6GHz not dual core my comp is 7 years old... so if i want faster gaming should i upgrade processor? i have 640 MB or somethin RAM help me out what should i upgrade?
    Mobile Member ShuckyD's Avatar
    Apr 2005
    S. Central PA
    3,646
    model name, etc.. of the computer would be helpful.. if not some specs (more)
    Mobile: Thinkpad T61 | WinXP Pro | C2D T8300 CPU | 3GB DDR2 | 320GB Hybrid SSD HDD | AGN & WWAN
    Desktop: Dell XPS 8300 | 3.4 Ghz Intel i7 | 8GB DDR3 | 1TB OS, 1.5TB Mirrored DATA
    GA
    5,414
    Hey speedy
    Download CPU-Z. Unzip it and run the cpuz.exe file. Goto the About tab and click the Registers Dump(.txt). Save the cpuz.txt file & post it here. That can help us research your PC. Here's examples...
    分かりますか。 carl33p's Avatar
    Feb 2006
    Gville, FL
    7,170
    9
    I would geuss its an Intel Pentium 4 2.6GHz Socket 478 CPU with PC2100 or PC2700 memory.
    Gaming performance relies heavily on the graphics processing unit.
    Short answer for you: If you want a better gaming experience, save up and buy a whole new PC. Upgrading something as outdated as your PC would be a waste of money.
    Oct 2007
    4
    how do i download the cpu id? where is the link?
    GA
    5,414
    Upper left corner, just below "Download latest version".
    Oct 2007
    4
    ignore this one
    Oct 2007
    4
    actually my comp was just frozen i got it now :P
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,194
    4
    Hey and Welcome to TechIMO!
    Sadly your cpu and system are just too subpar to spend money on for gaming, unless you want to play really old games. Also, you are running a p4 2.4ghz not a 2.6ghz and are running the slowest DDR available, pc2100.
    Best bet is to save up and build/buy a new pc.
    Member gcrussell1's Avatar
    Sep 2007
    Wuhan, Hubei, PRC
    99
    Your mobo likely wouldn't fit many or possibly any CPUs from the last 3 or 4 years. You're definitely at the point where you just need to replace the whole thing. Now, if you want your computer to run like it's 5 years old and not 7, you could look around for some older components, such as a 6xxx series Nvidia GPU, a 3.06 (or similar, depends on what your mobo could handle) HT P4, and some more PC2100 DDR memory, but you'd be buying borderline obsolete components to keep a borderline obsolete computer running at 2003-2004 levels, instead of 2002 levels.
    Bottom line, if you only plan on running games and other demanding programs from 4 or 5 years ago, you can afford to keep your computer running like it's 4 or 5 years old, but if you want to break into newer programs, you need a newer computer.
    GA
    5,414
    Yup, I agree with the other guys. If you want to upgrade your cpu you will also need a motherboard, ram, video, power supply upgrade. That's pretty much a new system.
    Do you have an upgrade budget?
    Member JRB3's Avatar
    Dec 2005
    Location, Location
    414
    Have you ever heard of the term "Flogging a dead horse" if you have then this is effectively what you are wanting to do. Listen to the guys. A complete system overhaul is required for an effective gaming system for 2007. The best thing you can do is to post an upgrade budget. Welcome to TechIMO, the home of sound advice, there are some eccentric members but they are part of the furniture and wont steer you wrong.
    "I hope you leave enough room for my fist because I'm going to ram it into your stomach and break your god-damn spine! "
  1. Processor Upgrade.
    By ibanez_bass in forum Processors, Memory, and Overclocking
    Last Post: December 21st, 2006, 03:50 PM
  2. upgrade processor
    By phillipanderson1 in forum General Tech Discussion
    Last Post: April 3rd, 2004, 11:10 PM
  3. Processor upgrade help.
    By mtesta1214 in forum Processors, Memory, and Overclocking
    Last Post: January 10th, 2004, 01:48 PM
  4. Processor upgrade
    By Contemplating in forum Mobile Computing
    Last Post: November 8th, 2003, 08:18 PM
